Pitot/static leak issues when using a "squat switch"
Old November 22nd 19, 11:23 PM posted to rec.aviation.soaring
JS[_5_]
Default Pitot/static leak issues when using a "squat switch"
On Friday, November 22, 2019 at 2:33:56 PM UTC-8, Scott Williams wrote:
On Friday, November 22, 2019 at 2:01:42 PM UTC-6, wrote:
Darryl, Ramy, Williams, et al
After installing a squat switch (such as the Peregrine brand), did your plumbing pass a pitot/static leak test?
I have heard gossip of the Peregrine switch having pitot/static leak issues. Is there another approved squat switch known not to leak?
This last summer I installed the Perigrine ground/air speed switch, with a small syringe applying just enough pressure to read 50 knots airspeed, reading is steady as a rock for over 20 minutes during a transponder-Ads_b check.
Good Luck,
Scott
Anyone had problems with these switches detecting an airspeed low enough in thermals to switch it to "on the ground" mode?
Old November 23rd 19, 01:00 AM posted to rec.aviation.soaring
Darryl Ramm
The trip airspeed is much lower than 50 knots.
This is a perfect example of a r.a.s. thread creating concerns out of nothing.
These work. Stop worrying about stuff and get things done.
Old November 23rd 19, 04:51 PM posted to rec.aviation.soaring
Dan Marotta
An interesting question, but I seldom look at the transponder control
head (TT22) to tell.Â* I do know that, when I turn the transponder on, it
reports GND on the screen and every time I've looked in flight (not that
often) it has always said, ALT.Â* I have noticed on my ClearNav II that
the ground speed has never shown less than 40-something knots except
while flying in wave but, again, I don't look at the ground speed that
often.
Good Luck,
Scott
Dan, 5J
Are air filters necessary on Pitot, static or TE lines? Pete[_9_] Soaring 15 December 18th 18 02:13 AM
Pitot Static 411 413 followup post A Lieberman Owning 12 June 18th 05 04:00 PM
My static system had a leak Derrick Early Instrument Flight Rules 1 August 25th 04 02:35 PM
pitot/static location Ray Toews Home Built 2 December 30th 03 12:52 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
