Pitot/static leak issues when using a "squat switch"
Old November 26th 19, 08:01 PM posted to rec.aviation.soaring
Default Pitot/static leak issues when using a "squat switch"
The STC approved Peregrine squat switch required for use with the Trig TN70 is $125.00 from Aircraft Spruce & Specialty. https://www.aircraftspruce.com/catal...it10-05913.php
It has been mentioned a cheaper pneumatic squat switch could be used if intended for an experimental glider running the TT22/TN72 combo.
Please identify suitable "experimental" pneumatic squat switches.
Thanks.
Old November 26th 19, 08:50 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Thanks.
http://www.craggyaero.com/transponder.htm
To confirm correct operation while sitting on ground, turn the transponder mode knob to alt and the display should say grd, then you can increase pitot pressure to above the stall speed setting and the transponder display will switch to alt.
If you fly in wave without this switch your ground speed may be very low and ATC will think you are on the ground.
AIR PRESSURE SWITCH/Normally open, 42 knots, adjustable.
$48.50
Richard
www.craggyaero.com
Old November 26th 19, 10:06 PM posted to rec.aviation.soaring
Tom BravoMike
Thanks.
$48.50
Richard
www.craggyaero.com
My glider can fly slower than 42 kts airspeed with flaps. What then? Can that be adjusted? How is it done?
Old November 27th 19, 05:15 PM posted to rec.aviation.soaring
Thanks.
$48.50
Richard
www.craggyaero.com
This switch says 34 Kts.
http://www.craggyaero.com/Trig/Airspeedswitch.pdf
The less expensive switch on this page
MLP503 I tested at 28 KTS
Richard
www.craggyaero.com
Old November 27th 19, 05:16 PM posted to rec.aviation.soaring
Thanks.
$48.50
Richard
www.craggyaero.com
Adjusted with a screw on the switch.
Richard
www.craggyaero.com
Are air filters necessary on Pitot, static or TE lines? Pete[_9_] Soaring 15 December 18th 18 02:13 AM
Pitot Static 411 413 followup post A Lieberman Owning 12 June 18th 05 04:00 PM
My static system had a leak Derrick Early Instrument Flight Rules 1 August 25th 04 02:35 PM
pitot/static location Ray Toews Home Built 2 December 30th 03 12:52 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
