Instrument panel labeling
Old January 10th 20, 07:36 PM posted to rec.aviation.soaring
Dave Nadler
Default Instrument panel labeling
On Thursday, January 9, 2020 at 9:26:27 PM UTC-5, wrote:
I'm looking for ideas on how to make professional looking placards/labels...
I've used https://www.frontpanelexpress.com - they do a great job.
They can do enclosures, for example lettering and cut-outs (DSUB, LED) on
the CAN-repeater I designed for Antares:
http://www.nadler.com/Antares/WCAN3_...ed_closeup.JPG
Great for larger parts like a fuse sub-panel as well as smaller stuff.
Hope that helps,
Best Regards, Dave
Old January 10th 20, 07:58 PM posted to rec.aviation.soaring
These are some great ideas. I like the durability of the anodized/engraved plates but was hoping to find something like the transfer that Cookie suggested from Decalprofx. If you read this, how durable have the decals been? Did you apply a clear coat over them? I think I could be happy with either of these results.
Doug
Old January 11th 20, 12:52 AM posted to rec.aviation.soaring
Cookie
Yes, I sprayed a super light coat of clear "fixative". Plane has yet to fly, so not sure of how it holds up.....but many aircraft use this system.
Cookie
Doug
Old January 12th 20, 02:58 AM posted to rec.aviation.soaring
Matt Herron Jr.
These are all great ideas, but if you want the most professional, readable, permanent, and flexible solution, use laser engraving of special plastic laminate sold by Johnson Plastics and others. The laser can cut a profile for the label(s), cut holes for connectors to mount through, and label the connectors. The material has a self adhesive backing so you can peal and stick to the panel.
I use LaserMax Rowmark White/Black 2 ply 1/16" thick with excellent results.. You can see a picture of my panel he https://www.dropbox.com/s/q6355wzj96...label.jpg?dl=0 A single placard takes care of all the items on the right side of the panel. I plan to do the required placards as well using this method.
Ideally a single label will handle multiple fuses/breakers, USB connectors, audio jacks, etc., and the profile will match your panel. You need to generate the artwork in something like Adobe Illustrator, or the like, and there are many services that will cut/engrave for you. For example, Rex at WSC did it for me. As suggested, choose a readable font like Helvetica bold for clarity. You can print to paper to check alignment, etc.
Have fun, and be prepared to be impressed.
Matt Herron
Old January 14th 20, 12:25 AM posted to rec.aviation.soaring
Cookie
Eh....to each his own...not my cup of tea...I think directly lettered looks way more professional. In production of panels (for all kinds of stuff, like test equipment etc)...they use silk screen...printed directly onto the surface
http://www.aircraftspecialty.com/instpanels.html
Here are a couple examples of silk screened lettering...most professional IMHO. These guys also do laser etch, right into the panel..I don't care fo rhte etch look...but he silk screen is 100% top notch!
Cookie
I use LaserMax Rowmark White/Black 2 ply 1/16" thick with excellent results. You can see a picture of my panel he https://www.dropbox.com/s/q6355wzj96...label.jpg?dl=0 A single placard takes care of all the items on the right side of the panel. I plan to do the required placards as well using this method.
Matt Herron
Old January 18th 20, 04:09 PM posted to rec.aviation.soaring
jfitch
Cookie
Matt Herron
On a smooth surface silkscreening can look OK. On a textured surface typical of many gliders, it does not look good, if it is readable at all. So, "it depends"....
ASW 19 instrument panel Charles Longley Soaring 14 November 1st 17 07:47 AM
P-39 Instrument-Panel - P-39 Instrument-Panel.jpg ... Miloch Aviation Photos 0 June 26th 16 01:47 AM
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
