Do you have to record a TN in the aircraft logbook ?
Old January 14th 20, 10:33 PM posted to rec.aviation.soaring
Darryl Ramm
Default Do you have to record a TN in the aircraft logbook ?
On Tuesday, January 14, 2020 at 10:00:47 AM UTC-8, wrote:
For an experimental glider, do you have to record a TN performed on the glider ?
Does it need and A&P signature ?
Dan
I would hope that questions like this go to the person who does your annual condition inspection. Including discussing with them any work you intended to do on the glider before doing it.
Is the TN a major alteration? Likely not, but if it is... what does your operating limitations say? If it is your FSDO likely needs to get involved and you need to go back to a test flight program. If it's not a major alteration...
You should be recording all significant stuff in the log. Including TNs. Why would you not, you want to establish the glider was well maintained and TNs complied with.
Unlike a type certified glider you don't need an A&P IA (or A&P) signature for a return to service.
How much does a lost aircraft logbook effect resale value? [email protected] Soaring 12 September 10th 19 05:46 AM
Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM Larry Dighera Piloting 29 December 2nd 15 09:29 PM
German Aircraft Logbook vontresc Soaring 2 April 1st 14 03:25 PM
Looking for info on world record jet aircraft Ted Parvo Home Built 25 July 17th 12 02:23 PM
