Glider electrics etc
Old February 5th 20, 07:52 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Glider electrics etc
On Wed, 05 Feb 2020 18:04:13 +0000, Benedict Smith wrote:
At 16:34 05 February 2020, Martin Gregorie wrote:
On Wed, 05 Feb 2020 14:29:32 +0000, Tim Newport-Peace
I realise having an inline Belling-Lee connector isn't ideal, the
more so
as it only connects to a 50cm extension with a BNF plug on the
radio end.
This setup was in the Libelle when I bought it, seems to work
OK, and so
it has stayed there. The short extension is necessary because
otherwise
the cable wouldn't reach the radio, let alone allow the panel to
slide
out far enough to connect or disconnect it from the radio.
I've thought about replacing it, but the free end of the original
cable
is in under the front coaming, too short to reach daylight. I'm
not keen
on making a solder joint in there, which would probably be no
better
electrically than leaving the Belling-Lee in place. Last but not
least, I
don't fancy pulling and replacing the entire cable either.
If the connector doesn’t need to come apart then you could simply wrap
it in a couple of turns of self amalgamating tape, that would be totally
waterproof and airtight, also it can be cut off if you did need to
disconnect it.
Ben.
Sounds good to me. Thanks.
Martin | martin at
Gregorie | gregorie dot org
Twin electrics jan olieslagers[_2_] Home Built 2 February 5th 10 07:45 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Wind/Solar Electrics ??? RST Engineering Owning 166 December 31st 05 02:38 AM
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 04:52 AM
