At 00:24 06 February 2020, Martin Gregorie wrote:
On Wed, 05 Feb 2020 22:06:34 +0000, Tim Newport-Peace wrote: At 19:52 05 February 2020, Martin Gregorie wrote: On Wed, 05 Feb 2020 18:04:13 +0000, Benedict Smith wrote: At 16:34 05 February 2020, Martin Gregorie wrote: On Wed, 05 Feb 2020 14:29:32 +0000, Tim Newport-Peace wrote: . I realise having an inline Belling-Lee connector isn't ideal, the more so as it only connects to a 50cm extension with a BNF plug on the radio end. This setup was in the Libelle when I bought it, seems to work OK, and so it has stayed there. The short extension is necessary because otherwise the cable wouldn't reach the radio, let alone allow the panel to slide out far enough to connect or disconnect it from the radio. I've thought about replacing it, but the free end of the original cable is in under the front coaming, too short to reach daylight. I'm not keen on making a solder joint in there, which would probably be no better electrically than leaving the Belling-Lee in place. Last but not least, I don't fancy pulling and replacing the entire cable either. -- If the connector doesn’t need to come apart then you could simply wrap it in a couple of turns of self amalgamating tape, that would be totally waterproof and airtight, also it can be cut off if you did need to disconnect it. Ben. Sounds good to me. Thanks. -- Martin | martin at Gregorie | gregorie dot org I have always prefered Internally-Glued Heat-Shrink over Tape. But getting back to the original posting, we should never recommend Belling-Lee and only use where there is no alternative. Tim Newport-Peace http://www.newportpeace.co.uk/icom.htm Agreed - obviously an extra 50cm of uncut cable with just a BNF on the end would be a lot better, but, as I said, I really don't want to mess about with soldering etc in mid-air on a piece of cable that comes out near the front end of the right side instrument panel support channel. However, if you can point me at a description of how to to use 'Internally-Glued Heat-Shrink over Tape' after, presumably, soldering the internal wire ends together, that would be interesting to know. Would it be easier than making upo some sort of clip to lock the B-L halves together? I had in mind sleving the Belling Lee with Heatshrink and the internal glue will seal to the outer of the co-ax eat each end. That should be moisture-proof. I would Never suggest splicing co-ax. However, another possible solution would be to use: https://tinyurl.com/tseyff8 or similar. No Soldering required. I don't particularly like these, but I like Belling Lee even less. At least you will be using a 50Ohm connector which is moisture proof. Tim Newport-Peace http://www.newportpeace.co.uk/icom.htm |
On Thu, 06 Feb 2020 11:38:38 +0000, Tim Newport-Peace wrote:
I had in mind sleving the Belling Lee with Heatshrink and the internal glue will seal to the outer of the co-ax eat each end. That should be moisture-proof. I would Never suggest splicing co-ax. Ah Ha! A simple fix that never occurred to me. Sticky heat-shrink ordered. Thanks. -- Martin | martin at Gregorie | gregorie dot org |
At 13:28 06 February 2020, Martin Gregorie wrote:
On Thu, 06 Feb 2020 11:38:38 +0000, Tim Newport-Peace wrote: I had in mind sleving the Belling Lee with Heatshrink and the internal glue will seal to the outer of the co-ax eat each end. That should be moisture-proof. I would Never suggest splicing co-ax. Ah Ha! A simple fix that never occurred to me. Sticky heat-shrink ordered. Thanks. -- Martin | martin at Gregorie | gregorie dot org Don't be in too much of a hurry. Let the warmer weather(?) dry out any moisture present or you will just be sealing the moisture in ;¬) Tim Newport-Peace http://www.newportpeace.co.uk/icom.htm |
Are you talking about a a disconnect on a wire going to a GPS antenna ?
Sorry about my ignorance regarding anything electrical. Dan |
On Thu, 06 Feb 2020 07:50:40 -0800, crosscountryboxco wrote:
Are you talking about a a disconnect on a wire going to a GPS antenna ? Sorry about my ignorance regarding anything electrical. No, we're talking abut the radio antenna. -- Martin | martin at Gregorie | gregorie dot org |
Thanks !
What about cutting and reconnecting (quick disconnect) the GPS antenna wires. What connector would you use ? Dan |
On GPS antennae, for what it's worth:
I opened a GPS puck antenna used for my PowerFlarm Portable, unsoldered the wires, cut the coax to the required length and soldered the center conductor and shield to the correct locations. I often had GPS dropouts on the Flarm.Â* I recently removed that antenna and, using the internal antenna on the portable unit, have had no more drop outs.Â* Just sayin'... On 2/6/2020 10:32 AM, wrote: Thanks ! What about cutting and reconnecting (quick disconnect) the GPS antenna wires. What connector would you use ? Dan -- Dan, 5J |
On Thu, 06 Feb 2020 09:32:50 -0800, crosscountryboxco wrote:
Thanks ! What about cutting and reconnecting (quick disconnect) the GPS antenna wires. What connector would you use ? I suppose that depends on what you're connecting the GPS antenna to and what sort of connection it uses. My RedBox FLARM has a BNF socket for the GPS puck connection. The supplied puck had way to much wire for my installation, so I cut the wire on a Gilsson puck down to 150mm (6") and soldered a right-angle BNF plug onto it. The FLARM system works perfectly. OTOH my EW logger uses a small brass? gold-plated? screw-on antenna connection. I didn't have ant replacements, so this time I wound the excess cable up into a neat 'donut' secured with a couple of cable ties, clipped the supplied ferrite core over the logger end, connected it all up and again it works very well. -- Martin | martin at Gregorie | gregorie dot org |
On Thursday, February 6, 2020 at 11:32:52 AM UTC-6, wrote:
Thanks ! What about cutting and reconnecting (quick disconnect) the GPS antenna wires. What connector would you use ? Dan Dan, It might be OK to shorten the GPS antenna's coax cable at the puck end (if you are particularly handy with a small tipped soldering iron) - but better to just loosely wrap up the excess cabling. The other end of the cable has the tricky and tiny SMA or MCX coaxial connectors which (unlike BNC and TNC connectors) requires some rather special expertise and tooling. As to your idea of "cutting and reconnecting (quick disconnect) the GPS antenna wires [really coax]" I would give a definitive NOT. The beauty of coax is that the outer shield protects the very small signal from interference riding on the inner conductor. Cutting the cable to properly insert a COAXIAL quick disconnect connector on the thin coax can interfere with that protection and is difficult to properly accomplish to say the least. Commercially made quick disconnects of this size are available from Craggy Aero (FLARM only?). My US$0.02. John DeRosa OHM |
Twin electrics | jan olieslagers[_2_] | Home Built | 2 | February 5th 10 07:45 PM |
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider | [email protected] | Soaring | 5 | November 19th 06 11:08 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
Wind/Solar Electrics ??? | RST Engineering | Owning | 166 | December 31st 05 02:38 AM |
Question on 172 M electrics... (1974 Skyhawk II) | [email protected] | Piloting | 8 | April 10th 04 04:52 AM |
