In 2003 I lost my fin and tailplane in a midair. I was able to get out very easily. I and the pilot of the other glider involved were very lucky. We both used our parachutes and were completely uninjured. I would not speculate on why the pilots of this K21 were unable to get out and am surprised that the report did not address that aspect. Would any of you ground a tug because the Flarm was giving problems?
On Monday, February 10, 2020 at 5:19:52 PM UTC-7, waremark wrote:
In 2003 I lost my fin and tailplane in a midair. I was able to get out very easily. I and the pilot of the other glider involved were very lucky. We both used our parachutes and were completely uninjured. I would not speculate on why the pilots of this K21 were unable to get out and am surprised that the report did not address that aspect. Would any of you ground a tug because the Flarm was giving problems? It sounds like they were about 2000" AGL. I would think that would give enough time to egress, assuming the G-forces were not pinning you in the seat, but it wouldn't be a lot of time. You would have to get out fast. |
Without a tail would the g forces not be 0 or even negative?. I would
expect the first result to be a bunt to inverted. Just wondering |
At 10:19 11 February 2020, Jim White wrote:
Without a tail would the g forces not be 0 or even negative?. I woul expect the first result to be a bunt to inverted. Just wondering I once saw a crash through loss of elevator. The time from loss of elevator to impact will have been less than 10seconds. Horrible but quick. |
On Tuesday, February 11, 2020 at 4:45:04 AM UTC-8, Jonathon May wrote:
At 10:19 11 February 2020, Jim White wrote: Without a tail would the g forces not be 0 or even negative?. I woul expect the first result to be a bunt to inverted. Just wondering I once saw a crash through loss of elevator. The time from loss of elevator to impact will have been less than 10seconds. Horrible but quick. I saw a glider loose the horizontal in the landing flare, 20 some years ago.. It pitched up and rolled left before the wing dung in and spun the aircraft around nearly hitting me. The pilot is still flying nearly every Saturday, and is one of the local "heroes". Funny side note, I watched that landing as the weekend before that same pilot had ground looped and nearly hit me as I was putting my bird back in box. |
This seems to happen every few years, where the tow plane makes a left turn and the glider make a right and they come around and collide. I changed the way we do it here so that the glider only makes a slight right turn, and then keeps his eye on the tow plane, so that at least one of the pair of planes can more easily maintain separation. When both planes make a 360° turn, neither of them can see the other. This kind of accident is the result.
Boggs |
When I was towing, I would visually confirm that the glider was off and
then roll steeply and dive.Â* If I hadn't felt the glider get off, I would fly straight and level for a bit to assure clearance before beginning a more moderate descent.Â* I also maintained awareness of any gliders that had not climbed away. I would blame both of the pilots in this accident but would assign most of the blame to the tow pilot.Â* Making what amounts to a level turn just after release is asking for trouble. On 2/11/2020 8:51 AM, Waveguru wrote: This seems to happen every few years, where the tow plane makes a left turn and the glider make a right and they come around and collide. I changed the way we do it here so that the glider only makes a slight right turn, and then keeps his eye on the tow plane, so that at least one of the pair of planes can more easily maintain separation. When both planes make a 360° turn, neither of them can see the other. This kind of accident is the result. Boggs -- Dan, 5J |
On Tuesday, February 11, 2020 at 8:51:26 AM UTC-7, Waveguru wrote:
This seems to happen every few years, where the tow plane makes a left turn and the glider make a right and they come around and collide. I changed the way we do it here so that the glider only makes a slight right turn, and then keeps his eye on the tow plane, so that at least one of the pair of planes can more easily maintain separation. When both planes make a 360° turn, neither of them can see the other. This kind of accident is the result. Boggs Agree with your logic. As a tow pilot and glider pilot I have circled around on several different flights over the last 7 years only to be too close to other aircraft. I began to do and teach what I saw at a contest a few years back: Tow plane descends and continues straight before maneuvering back toward airport (efficient.) Glider circles and (re)gains visual contact before continuing flight. Make the student verbally call tow plane out before moving onto soaring or lesson. Creates maximum separation. Warning: This must be part of (US) preflight briefing or one pilot or other is going to say "What in the heck is that guy doing?" Cheers Gene |
Jonathan St. Cloud wrote on 2/11/2020 5:40 AM:
On Tuesday, February 11, 2020 at 4:45:04 AM UTC-8, Jonathon May wrote: At 10:19 11 February 2020, Jim White wrote: Without a tail would the g forces not be 0 or even negative?. I woul expect the first result to be a bunt to inverted. Just wondering I once saw a crash through loss of elevator. The time from loss of elevator to impact will have been less than 10seconds. Horrible but quick. I saw a glider loose the horizontal in the landing flare, 20 some years ago.. It pitched up and rolled left before the wing dung in and spun the aircraft around nearly hitting me. The pilot is still flying nearly every Saturday, and is one of the local "heroes". Funny side note, I watched that landing as the weekend before that same pilot had ground looped and nearly hit me as I was putting my bird back in box. Did damage from the earlier ground loop contribute to losing the horizontal the next week? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
My glider blunted and I was hanging from my straps and fell out as soon as I released the harness. My mohair was at 3000 ft agl but I would have had no problems from 2000.
Anyway, reading this will make me pay more attention to where the tug goes after release. At our club to avoid shock cooling the tug generally accelerates away level before reducing power, and the glider does a climbing turn to slow down. |
PowerFLARM Core or LXNAV PowerMouse Installation in Towplane | Paul Remde | Soaring | 1 | October 2nd 19 04:58 PM |
Powerflarm in towplane anecdotal experiences | son_of_flubber | Soaring | 0 | July 29th 19 04:30 PM |
Cirrus collides with Glider/Towplane | Jody | Soaring | 9 | February 7th 10 03:14 AM |
towplane collides with glider, prop hits wingtip | [email protected] | Soaring | 21 | September 1st 09 07:24 PM |
Glider - Towplane Signals | Mike the Strike | Soaring | 24 | March 26th 05 09:33 PM |
