Possible to convert Ventus Ct to Cm?
Old February 21st 20, 03:49 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
Default Possible to convert Ventus Ct to Cm?
On Thu, 20 Feb 2020 19:15:45 -0800 (PST), "Mike N."
Thanks for the sarcasm, wothless and not helpful at all, but semi typical for R.A.S.
So let me spell it out for you, can I take a Ventus Cm Solo motor and control panel, and install it in a Ct?
As I stated in my O.P. I was just thinking out loud.
I realize it is not likely to be a viable option.
That being said, the motors in both the Ct and Cm are designed for easy removal and re-installation so the glider can be flown sans motor without to much effort.
Which is why I was thinking MAYBE it would not be too difficult to transition a Cm motor to a Ct.
Of course you'd have to know if the pylon mounts are the same, swap out the motor control panel, etc.
Thanks for any useful feedback.
Might be worth clearing up contradictory posts... is it cT to cM, as
your heading states, or cM to cT, as your 2nd posts indicates?
In any event, worth noting that the cT and the cM share the same Solo
2350 engine. Difference is the cM has a larger diameter prop (till
folding), starter, and throttle.
Bob
Old February 21st 20, 05:30 AM posted to rec.aviation.soaring
Tango Whisky
I did ask the question Schempp-Hirth last year on behalf of a friend, and the flat answer was "no".
Old February 21st 20, 12:25 PM posted to rec.aviation.soaring
Mike N.
To clarify, Ct to Cm.
When I posted this, I thought it was unlikely to be a viable option, but wanted to ask just in case there was a path to do this.
As noted the solo motor used is the same, so in theory adding a starter, changing the prop and controls might be viable and I was exploring that option. I should have been more specific in O.P.
My apologies to Sky Surfer, I've seen a lot of sarcastic disingenuous comments on R.A.S. and mis-read your intent.
convert points kml/kmz to cup [email protected] Soaring 6 April 5th 18 02:57 AM
Looking for a formula to convert Kg/m2 to LB/FT2 Zen63T Soaring 12 December 16th 12 01:37 AM
How do I convert an instrument rating? tfitch03 General Aviation 0 October 27th 10 02:21 AM
Convert Cherokee 140 to 180? Tim Long Owning 24 January 11th 05 03:42 PM
Can I convert my D/C H10-76 to G.A. use? Jet Mech in Tampa Aviation Marketplace 1 May 28th 04 02:13 AM
