On Wednesday, March 25, 2020 at 5:45:05 AM UTC-7, John McLaughlin wrote:
Thanks Martin. I think that after maybe another week or two of lockdown, I'm going to be bored enough to make something around my aluminium ladders using a couple of spare wheelbarrow wheels and some scraps of timber. If I can get the ground clearance right, as well as the total length, width, and wheel position, that should do it. And it'll keep the neighbours amused. At 11:35 25 March 2020, Martin Gregorie wrote: On Wed, 25 Mar 2020 09:40:18 +0000, John McLaughlin wrote: I want to bring my trailer home to do some maintenance while we're all grounded, but I'm not sure if I can access my house from the road. I have a 90deg bend to get around and then the second issue is a short, steep slope, which may ground the back of the trailer. So my question is, if I measure things up, how can I calculate whether access is theoretically possible? Is there any advice on the internet - I can't find anything? I don't want to just try the trailer for size because I fear getting it stuck. You could always model it: 1) use a 25m tape measure +_ compass to draw an accurate map of the track on a decent sized sheep of paper, say A3 and use a sensible scale, say 1:25 or 1:50 Draw in the track to its correct width and don't forget obstacles, (hedges, poles, gateways, buildings etc. Seeing that there's a steep slope involved, use some scrap foam plastic to make a scale 3D surface and glue the map to it I'd use a hiking GPS or Google Earth to measure the height difference unless you already know that. OR (in order of decreasing accuracy) Walk the track centre line with a GPS OR Take measurements off Google Earth 2) measure length + width of trailer + towbar and towing vehicle. Make cardboard cutouts of the plan view of trailer and car. Add a scale towbar to the trailer (lollypop stick would be fine) and add something to the trailer where the wheels should be. Rubber toy wheels would be best, but small blocks of wood or foam should also work. Connect car and trailer with a drawing pin or similar, placed where the tow ball is in the car. 3) now you can move car+trailer models along the track and see how close the trailer comes to hitting anything. At least, thats how I'd do it and, even if it takes time to do properly, its something else to do while in COVID lockdown. Making the measurements can reasonably be described as 'your daily walk'. HTH -- Martin | martin at Gregorie | gregorie dot org take videos for us! We are bored. |
Cobra Trailer front access door .... | Ron Gleason | Soaring | 6 | September 9th 14 08:55 PM |
Anyone with easy access to a Komet trailer? | Morteza Ansari | Soaring | 2 | October 13th 13 03:11 AM |
ADC intercept calculation... | dtvonly | General Aviation | 0 | August 17th 12 11:14 PM |
OLC score calculation? | ttaylor at cc.usu.edu | Soaring | 4 | August 24th 05 01:50 AM |
Three leg GS to TAS calculation | Mike Rapoport | Owning | 21 | September 12th 04 04:37 AM |
