Do you own an IMI Power Rigger?
Old May 27th 20, 02:47 AM posted to rec.aviation.soaring
2G
Default Do you own an IMI Power Rigger?
On Tuesday, May 26, 2020 at 3:35:13 AM UTC-7, William Kautter wrote:
I'm considering the purchase of an IMI Power Rigger. If you own one I would very much appreciate information about your experience with it.
Bill
Wings & Wheels has a video that shows how it works. I have one and it works great except for ONE thing: if you leave it on, or you don't use it over the winter, the battery will die and you are dead in the water, most likely at the time you REALLY want to use it. You fix this by:
1. Buying a 2nd battery.
2. Buying a mating battery connector so you can power it from another battery (someone posted a link where you can buy the connector).
It's rated to lift something like 250 lbs (IF the battery is good and charged). I had no problem with my ASH31Mi inner wing panels. The quality of construction is absolutely excellent (CNC machined parts, for example). The tires are solid rubber, so no flat tires at the start of the season (been there, done that). Being able to tweak the wing position remotely while searching for the exact alignment position is a major plus. I need to come up with a method of preventing the first wing from being pushed out by the second wing, but this is no fault of the rigger.
My only complaint is it is a bit on the pricey side, but I think you get what you pay for.
Tom
Old May 27th 20, 03:12 AM posted to rec.aviation.soaring
6PK
Bill
Tom
"" if you leave it on, or you don't use it over the winter, the battery will die and you are dead in the water""
These are NiCad batteries. Playing with model airplanes a long while ago, the rule was to always charge the batteries before and after and also cycle them to prevent a memory built up. Although I don't have a battery cycler any longer the next best thing is to run them down to "almost" all the way time to time and charge them back up. I kind of whish they offered these units with the newer lithium ion stuff through...
Old May 27th 20, 04:30 AM posted to rec.aviation.soaring
2G
Bill
Tom
No, they aren't NICADs - the IMI uses a 2.9 AHr SLA battery which self-discharge over a number of months.
Tom
Old May 27th 20, 02:02 PM posted to rec.aviation.soaring
Mike Clarke[_3_]
you own one
I=
with it.
=20
Bill
=20
one and it
w=
use it
ov=
most
lik=
from another
b=
connector).
good and
c=
The quality
of=
example).
Th=
(been=
remotely while
se=
to come
up=
out by the
se=
=20
you
ge=
t what you pay for.
=20
Tom
=20
battery
w=
while
ago,=
also
cycl=
battery
cycler=
all the
way=
offered these
u=
which
self-disc=
Tom
And the tyres are inflatable, not solid. Would be rather heavy to
lift into the trailer if the tyres were solid. All this is in the
description on the IMI website anyway.
Mike
Old May 27th 20, 04:23 PM posted to rec.aviation.soaring
2G
you own one
I=
with it.
=20
Bill
=20
one and it
w=
use it
ov=
most
lik=
from another
b=
connector).
good and
c=
The quality
of=
example).
Th=
(been=
remotely while
se=
to come
up=
out by the
se=
=20
you
ge=
t what you pay for.
=20
Tom
=20
battery
w=
while
ago,=
also
cycl=
battery
cycler=
all the
way=
offered these
u=
which
self-disc=
Tom
Mike
Yeah, it was the wing wheel I got from Craggy Aero that has a solid tire.
Tom
Old May 27th 20, 04:24 PM posted to rec.aviation.soaring
2G
you own one
I=
with it.
=20
Bill
=20
one and it
w=
use it
ov=
most
lik=
from another
b=
connector).
good and
c=
The quality
of=
example).
Th=
(been=
remotely while
se=
to come
up=
out by the
se=
=20
you
ge=
t what you pay for.
=20
Tom
=20
battery
w=
while
ago,=
also
cycl=
battery
cycler=
all the
way=
offered these
u=
which
self-disc=
Tom
Mike
Tom
Old May 27th 20, 03:30 PM posted to rec.aviation.soaring
6PK
Bill
Tom
Tom
My mistake, you are absolutely correct I just confirmed it too..
Old May 27th 20, 10:05 PM posted to rec.aviation.soaring
jfitch
Bill
Tom
Tom
Easy enough to replace with an LFP. I did that on my Cobra electric. You can leave the LFP half flat without affecting life expectancy, and the self discharge rate is low.
Old May 29th 20, 01:56 AM posted to rec.aviation.soaring
@Tom/2G
"I need to come up with a method of preventing the first wing from being pushed out by the second wing..."
Try taping the first wing after you insert it.
Doug
W24
Old May 29th 20, 02:16 AM posted to rec.aviation.soaring
2G
On Thursday, May 28, 2020 at 5:56:26 PM UTC-7, wrote:
@Tom/2G
Doug
W24
Yeah, that was my first thought. I will try it next time I rig (I have the glider tied down with covers on and only rig 2-3 times a year).
Tom
Looking to buy a wing rigger. Marcin S Soaring 4 July 19th 17 02:13 PM
IMI One Man Rigger Question GeneReinecke Soaring 1 February 7th 17 09:41 AM
Wanted to buy: One Man Rigger [email protected] Soaring 26 June 19th 15 09:18 AM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
