Do you own an IMI Power Rigger?
Old May 27th 20, 02:02 PM posted to rec.aviation.soaring
Mike Clarke[_3_]
Default Do you own an IMI Power Rigger?
At 03:30 27 May 2020, 2G wrote:
On Tuesday, May 26, 2020 at 7:12:20 PM UTC-7, 6PK wrote:
On Tuesday, May 26, 2020 at 6:47:45 PM UTC-7, 2G wrote:
On Tuesday, May 26, 2020 at 3:35:13 AM UTC-7, William
Kautter wrote:
I'm considering the purchase of an IMI Power Rigger. If
you own one
I=
would very much appreciate information about your experience
with it.
=20
Bill
=20
Wings & Wheels has a video that shows how it works. I have
one and it
w=
orks great except for ONE thing: if you leave it on, or you don't
use it
ov=
er the winter, the battery will die and you are dead in the water,
most
lik=
ely at the time you REALLY want to use it. You fix this by:
1. Buying a 2nd battery.
2. Buying a mating battery connector so you can power it
from another
b=
attery (someone posted a link where you can buy the
connector).
It's rated to lift something like 250 lbs (IF the battery is
good and
c=
harged). I had no problem with my ASH31Mi inner wing panels.
The quality
of=
construction is absolutely excellent (CNC machined parts, for
example).
Th=
e tires are solid rubber, so no flat tires at the start of the season
(been=
there, done that). Being able to tweak the wing position
remotely while
se=
arching for the exact alignment position is a major plus. I need
to come
up=
with a method of preventing the first wing from being pushed
out by the
se=
cond wing, but this is no fault of the rigger.
=20
My only complaint is it is a bit on the pricey side, but I think
you
ge=
t what you pay for.
=20
Tom
=20
"" if you leave it on, or you don't use it over the winter, the
battery
w=
ill die and you are dead in the water""
These are NiCad batteries. Playing with model airplanes a long
while
ago,=
the rule was to always charge the batteries before and after and
also
cycl=
e them to prevent a memory built up. Although I don't have a
battery
cycler=
any longer the next best thing is to run them down to "almost"
all the
way=
time to time and charge them back up. I kind of whish they
offered these
u=
nits with the newer lithium ion stuff through...
No, they aren't NICADs - the IMI uses a 2.9 AHr SLA battery
which
self-disc=
harge over a number of months.
Tom
And the tyres are inflatable, not solid. Would be rather heavy to
lift into the trailer if the tyres were solid. All this is in the
description on the IMI website anyway.
Mike
Old May 27th 20, 04:23 PM posted to rec.aviation.soaring
2G
you own one
I=
with it.
=20
Bill
=20
one and it
w=
use it
ov=
most
lik=
from another
b=
connector).
good and
c=
The quality
of=
example).
Th=
(been=
remotely while
se=
to come
up=
out by the
se=
=20
you
ge=
t what you pay for.
=20
Tom
=20
battery
w=
while
ago,=
also
cycl=
battery
cycler=
all the
way=
offered these
u=
which
self-disc=
Tom
Mike
Yeah, it was the wing wheel I got from Craggy Aero that has a solid tire.
Tom
Old May 27th 20, 04:24 PM posted to rec.aviation.soaring
2G
you own one
I=
with it.
=20
Bill
=20
one and it
w=
use it
ov=
most
lik=
from another
b=
connector).
good and
c=
The quality
of=
example).
Th=
(been=
remotely while
se=
to come
up=
out by the
se=
=20
you
ge=
t what you pay for.
=20
Tom
=20
battery
w=
while
ago,=
also
cycl=
battery
cycler=
all the
way=
offered these
u=
which
self-disc=
Tom
Mike
Tom
Looking to buy a wing rigger. Marcin S Soaring 4 July 19th 17 02:13 PM
IMI One Man Rigger Question GeneReinecke Soaring 1 February 7th 17 09:41 AM
Wanted to buy: One Man Rigger [email protected] Soaring 26 June 19th 15 09:18 AM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
