How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
Old June 8th 20, 08:14 PM posted to rec.aviation.soaring
Default How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
Soooo....."no welding allowed"......how do they make the ring? Just asking......usually round "wire/rod", bent, welded together.....
Shrug....
Old June 8th 20, 08:30 PM posted to rec.aviation.soaring
On Monday, June 8, 2020 at 1:14:41 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
Shrug....
Forging a ring involves bending the stock in a circle with varying amounts of overlap- sometimes one or more full circles, but more often a lap of about 1/3 the circumference. Then it is heated to a bright, glowing temperature and beaten into the final shape. Hardening is sometimes done by quenching in oil. Linked rings are made by forging the first ring and looping the second though it and forging by the same method.
Old June 9th 20, 01:24 AM posted to rec.aviation.soaring
AS
Shrug....
I am just speculating here but two interlocking rings could be easily made as an investment casting (lost wax casting). Given that it is a Cr-Va alloy, the raw cast product can be heat treated and quenched in oil, which would explain the blackened appearance when new.
I will see if I can get my hands on a discarded pair and have our metallurgists take a look at.
Uli
'AS'
Aluminum angle Lou Home Built 11 June 25th 07 11:57 PM
Blue Angle #3 Elmshoot Naval Aviation 10 May 24th 04 10:35 PM
Another angle... tongaloa Home Built 0 February 27th 04 11:13 PM
The Dan Rather Angle Dude Owning 7 January 18th 04 09:10 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
