My September 2017 visit to GP Gliders
Old August 20th 20, 02:22 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
Default My September 2017 visit to GP Gliders
On Wed, 19 Aug 2020 10:48:30 -0600, Dan Marotta
Remember your high school chemistry (or was it physics?).* Water gives
up 1 calorie per gram per degree C while cooling.* To transition from
water at zero deg C to ice at zero deg C requires the loss of 80
calories per gram per degree C.* That's a lot of heat to be lost!* Sure,
you have a large surface area, but you have a very large volume as
well.* It would take quite some time to freeze a ballast tank.
Bottom line is I never worried about icing the ballast tanks (when I had
them) at sub-freezing temperatures.* Now freezing the dump valves is a
different issue, but not really if you fly your glider all the way to a
stop.* I once landed my LAK-17a with nearly 50 gallons on board and
didn't notice until after getting out of the glider.* Another time, one
dump valve stuck closed and, again, I landed with 25 gallons in one wing
and empty in the other.* I didn't notice until coming to a stop and the
full wing dropped heavily.
.... text deleted
Maybe off topic, but what worried me in past years when I flew in the
New Mexico mountains was not the wing ballast tanks, but the tail
tank.
I always had visions of the tail tank freezing and failing to dump
when I dropped ballast, leaving my CG too far aft.
I usually left the tail tank empty if I was expecting high altitutes.
Bob
Old August 20th 20, 04:03 AM posted to rec.aviation.soaring
I fly NM with water regularly, both in the wings and the tail. I generally fly dry in the early spring when temperatures are still sub freezing at 17,000+ and start filling up during the summer. No problems so far, but if I do decide to use water in the tail tank when it's really cold, I can always add some propylene glycol antifreeze. Several of our more manic pilots do that and it seems to work well.
Old August 21st 20, 10:35 PM posted to rec.aviation.soaring
jfitch
Not telling you what to do but in the Truckee/Minden area it is routine to fill the tanks and fly all day at sub freezing temps - probably 4 - 5 hours below freezing. We did have one case of the tail tank dump valve on a DuoDiscus leaking, which dribbled water onto the rudder hinge and controls, which froze the rudder in position. Pilot flew carefully home on a 200 mile final glide, descending through warmer temps and it melted enough to break loose.
FAR 2017 ADS-B re gliders Eric Bick (ZN7) Soaring 4 January 24th 17 04:40 PM
Koenigsdorf 08 September 2012 - File 1 of 1 - Koenigsdorf Segelflugzentrum 08 September 2012 Compressed Contact Sheet.jpg (1/1) Transistor Bubblezap Aviation Photos 0 September 9th 12 09:57 PM
The Last Place I Would Want To Visit. Michael Baldwin, Bruce[_2_] Products 2 September 1st 07 04:38 AM
Pensacola Visit Lee Witten Naval Aviation 10 January 20th 05 06:55 PM
Boston Visit PaulH Piloting 8 August 22nd 04 03:38 PM
