On Friday, September 18, 2020 at 8:30:59 AM UTC-7, wrote:
On Tuesday, September 15, 2020 at 10:48:13 AM UTC-7, Nick Kennedy wrote: Didn't want to hijack the current FES tread so I thought I'd start a new one. This topic came up over dinner a couple of weeks ago. When you add all the following into a pot and stir, whats the "Best" Say for Western Great Basin flying. I think it may be the Carat, but I don't know much about it. CX thinks its the DG 800 series, but all I know is since he bought that thing its been a endless battle to keep it running. But it does climb well.. FACTORS Reliability Maintenance required to keep it running XC flyability, performance and control feel Storability Rigging Initial cost High density climb performance Range Cockpit layout and seating Parts availability Insurance cost Landing gear complexity Overall quality Nick T I have been flying my Carat for 3 yrs now and have no regrets. I purchased it for retirement so I can go to the local airport when I travel to fly. Scarcity of towplanes was the driving factor. The Carat is the Discus wing and tail mounted on their fuselage. I have never had a problem with the Sauer engine. Performance has been great with summer time launches in Tucson and Moriarty. One other flies out of Parowan, Ely and Nephi. I love the upright seating and the convenentional gear makes taxiing a breeze since neither wing is down. The only two negatives have been high wing loading in weak conditions and it tends to do poorly in heavy sink. Falls out of the sky if you have to fly above 90 kias. Super easy assembly and great trailer. I'm told it sounds like a J3 cub. Love it. Sorry Nick, I can't help with the cost to replace an ASH-26E engine with all the bits. Fortunately, I haven't had to find out! I do hope to see you again sometime in the Great Basin. It's been a long time. Maybe someone that's been thru this exercise could help. Painful, I'm sure! Russ |
Love my DG 400. I have had to do a little work but able to get parts so far. No motor breakdown work.
On the gear, there is a service bulletin that covers a number of the DG models. It was done to my glider and makes the mechanism more robust with a positive catch and spring on the handle. Also changing the gas spring on the gear is important if not done in years. Vibration, I have had the prop balanced by Russel Brown at Seminole when flying at the Seniors. Took about an hour using a Dynavibe. Put small washers in different locations around the prop hub where it bolts together. Very significant vibration reduction, pitch of prop changed, and even got a couple hundred RPM on static run. Great bird for the money. Kevin 92 |
ASW 20C Motorglider | Nick Kennedy[_3_] | Soaring | 3 | February 7th 19 11:17 AM |
FS: DG-400 Motorglider | 2G | Soaring | 0 | September 20th 13 02:32 PM |
IFR in motorglider? | cp | Soaring | 28 | March 9th 08 12:02 AM |
Motorglider Tug | Ray Lovinggood | Soaring | 21 | November 13th 04 04:06 AM |
motorglider | KsiTau | Soaring | 0 | September 4th 04 09:10 AM |
