Best Overall Motorglider available today?
Old September 28th 20, 07:18 AM posted to rec.aviation.soaring
Slawek Piela[_2_]
Default Best Overall Motorglider available today?
Why nobody mentioned Antares 20/21E?
S
Old September 28th 20, 02:57 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
The Antares 20E is a very nice handling machine with a good high speed
glide angle, comfortable (crash resistant) cockpit and excellent simple
engine controls (one lever does it all). The climb rate is very good (a
large, 2m diameter, slow revving prop and engine doors that are closed
during climb all help). The build quality is very nice.
In EASA land you can extend the actual ARC inspection to every three
years; the A/C can generate its own system reports which can be sent to
your inspector, if all is well a physical inspection is not required
annually.
However the total full power engine run time is only about 13 minutes so
after a ~3000 foot climb (I've averaged 6 minutes/launch over the last 5
years) you might have 50 - 60% battery capacity remaining: realistically
this will give you one further good climb so for many pilots the limited
battery capacity is seen as a problem.
The A/C is electrically/electronically very complex, the engine doors, the
engine erection/retraction and the U/C are all electro-hydraulic: even in
Europe any serious issue might mean a trip to Lange Aviation,
Zweibrucken, NW Germany.
It's expensive; it's the nicest motor glider I've owned/operated. Things
that could be better: -
(i) Engineers & inspectors with experience of Antares maintenance are
thin on the ground.
(ii) The official Flight & Maintenance Manuals are in still in German!
Old September 28th 20, 03:04 PM posted to rec.aviation.soaring
Dave Nadler
Before you purchase any motorglider, you will want to talk to a few owners
about their ownership experience, especially reliability and factory support.
Old September 28th 20, 05:22 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
owners
support.
I agree totally: what you might well discover is that the reliable motor
glider does not yet exist. Given this, good factory support is very
desirable.
Old September 28th 20, 06:19 PM posted to rec.aviation.soaring
jfitch
At least individual examples do exist. I've owned mine for 20 years, in that time I have had exactly 1 failure to start (first start after the winter layup, fouled plugs), and no inflight failures at all. Other than scheduled maintenance per the manual, the list of repairs in 20 years has been:
* replaced exhaust muffler per A/D
* replaced water pump due to progressively worsening seal
* preemptively replaced belt idler bearings which were judged to be noisy
* replaced coil #1, internally intermittent
I've rarely owned a car that had fewer repairs. I'm not going to argue that this glider is as reliable as a modern car, but with vigilant maintenance, reliability has not been bad relatively speaking. Perhaps I have been lucky, but I know other owners who are equally lucky. I own two boats, each of which has required more unscheduled maintenance than has the glider. Boats and gliders are both made in prototype quantities, an expectation of reliability equal to an automobile (made in millions) is naive. But of course, even in an automobile, good factory support is desirable.
desirable.
Old September 28th 20, 06:44 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
jfitch wrote on 9/28/2020 10:19 AM:
desirable.
My experience with my ASH 26E parallels Jon's: over 26 years, 4000+ hours, 200
engine hours, except for these engine related issues...
-I've had one failure to start in-flight; probably my fault as it started
immediately on the ground shortly after landing
-replaced the propeller drive belt after 20 years "just because"
-the air spring on the mast was replaced once
-oil sensor leaked, replaced
-I have not replaced a coil, but I did replace the flywheel per an AD the second
year or so.
-I've only lost two or three soaring days due to propulsion system issues, as most
maintenance could be deferred to non-soaring periods (like winter)
I flew towed gliders for about 3000 hours, and lost many days due to towplane
issues: no pilot or towplane down for various mechanical problems. I can take my
26E to almost any airport, where I can expect to launch and then return 5-6 hours
later, even the weather doesn't cooperate. That's my idea of a reliable glider!
Try that with a towed glider, and your "reliability" will be much worse.
Old September 29th 20, 10:24 PM posted to rec.aviation.soaring
You did not say which aircraft you own...
Matt
Old September 30th 20, 12:54 AM posted to rec.aviation.soaring
jfitch
ASH26Mi. Eric's story reminds me that I have had to replace the oil sender as well (though that was done at the scheduled annual, no down time). I have lost only one day of soaring, the failure to start after winter layup. I have flown it twice without the engine installed, once when the water pump was being replaced just to see how it would fly, and once in the midst of my engine conversion when the soaring looked too good to pass up and the new engine wasn't ready. When the coil became intermittent the engine ran fine on the other coil, but I chose to take a tow that day out of an abundance of caution. Those occasions are the only instances of it being towed. Like Eric, I have flown numerous days when either there was no tow plane, or the wait was so long several pilots gave up and drank beer. So I think I can truthfully say it has gotten me launched more reliably than an engineless glider. Picking my own launch time has been the best benefit though.
I've been meticulous about maintenance, and make no mistake, there is much more maintenance on a motorglider than one without.
Matt
Old September 30th 20, 08:35 PM posted to rec.aviation.soaring
Thanks! I am familiar with the ASH-26E, but I haven't seen much online about the -Mi. Are these quite different?
Matt
ASW 20C Motorglider Nick Kennedy[_3_] Soaring 3 February 7th 19 11:17 AM
FS: DG-400 Motorglider 2G Soaring 0 September 20th 13 02:32 PM
IFR in motorglider? cp Soaring 28 March 9th 08 12:02 AM
Motorglider Tug Ray Lovinggood Soaring 21 November 13th 04 04:06 AM
motorglider KsiTau Soaring 0 September 4th 04 09:10 AM
