Best Overall Motorglider available today?
Old October 3rd 20, 01:41 AM posted to rec.aviation.soaring
Dave Nadler
Default Best Overall Motorglider available today?
On Friday, October 2, 2020 at 12:46:57 PM UTC-4, jfitch wrote:
While the Mi engine is better, the E engine is certainly adequate
Thanks Jfitch for showing us your beautiful 26mi at the convention.
Can you remind us why you decided to do the conversion from original engine?
Thanks,
Best Regards, Dave
Old October 3rd 20, 08:30 AM posted to rec.aviation.soaring
John Galloway[_2_]
I flew an ASH26e for 2 seasons and now have a V3M which matches its advertised climb rate of 630fpm with its 62hp fuel injected Solo engine taking off from 360ft msl. The 26e with the carb engine got around 500pm so I surprised me to hear the the 26Mi, with a lower power engine than my V3M, will manage 800fpm from sea level. 800fpm seems an extraordinary increase.
The 26e is a lovely glider and the engine is, of course, much quieter smoother than 2 cylinder 2-strokes but the rotary engine is too vulnerable to catastrophic internal damage if anything goes wrong with the marginal at the best of times rotor air cooling and the internal oil misting. The saying about self launching glider IC engines is - "with the Solo you will probably get lots of relatively small problems, with the rotary you'll get fewer problems but when you do it could be a very big one". There are certainly a few replaced rotaries in gliders that I know of and that is a big bill. I had the fan belt fall off and the engine rotor air rapidly overheat but got away with it.
Old October 3rd 20, 08:56 AM posted to rec.aviation.soaring
Paul T[_4_]
Is there a rec.aviation.mortorglider for all these boys that don't fly
sailplanes???
Old October 3rd 20, 02:07 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Paul T wrote on 10/3/2020 12:56 AM:
sailplanes???
You are asking about what we call "touring motorgliders". The best place to start
is the Touring Motorglider Association forums:
https://www.motorgliders.org
Old October 3rd 20, 03:28 PM posted to rec.aviation.soaring
Dan Marotta
Touring motorgliders seem to be simply airplanes with longer wings.
sailplanes???
place to start is the Touring Motorglider Association forums:
Dan, 5J
Old October 3rd 20, 06:01 PM posted to rec.aviation.soaring
kinsell
sailplanes???
I believe he was saying that motorgliders aren't really sailplanes and
would like discussions on such to move elsewhere.
Maybe if he doesn't want to read about motorgliders, he could avoid
clicking on threads mentioning motorgliders?
Old October 3rd 20, 10:43 PM posted to rec.aviation.soaring
Paul T[_4_]
sailplanes???
place
Such a cynic - but no, anything with an engine in it is not a sailplane -
its a
different game - maybe better, maybe worse, but definitely different - but
personally I'd have a JS2/5 if I win the lottery.
Old October 3rd 20, 11:42 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Paul T wrote on 10/3/2020 2:43 PM:
sailplanes???
place
its a
Equipment does change the game: 1-26 vs Nimbus 4 is a different game.
The area also changes the game: Appalachian ridges vs Argentina wave is a
different game.
The launch availability changes the game: Daily access to a tow vs weekend only is
a different game.
Retrieve ease changes the game: a very dedicated (or paid) crew vs the unassisted
pilot is a different game.
My point: The common factor is we are all flying sailplanes, and there are many
factors affecting the "game". To argue a Nimbus 4 is a sailplane and a Nimbus 4M
isn't ignores what happens between the start and finish of the soaring.
Eric Greenwell - Washington State, USA (change ".netto" to ".us" to em"l me)
Old October 5th 20, 08:17 AM posted to rec.aviation.soaring
Carlo Orsini
I thought the same thing...............before checking width between shoulders on JS2!
Old October 3rd 20, 05:10 PM posted to rec.aviation.soaring
jfitch
I have written an application that will analyze an IGC file (or many IGC files at once) to calculate time to climb and climb rate. I dumped 20 years worth of my IGC files into it. The climb rate at sea level with the E engine was a bit over 600 if memory serves, and a bit over 800 with the Mi (I do not fly often at sea level). About the same percentage increase at high altitude. If you want to send me some IGC files, I can throw them into the same app.
There have been a couple of instances of fan belt failures on the rotary, a few of us have installed warning indicators for this possibility.
ASW 20C Motorglider Nick Kennedy[_3_] Soaring 3 February 7th 19 11:17 AM
FS: DG-400 Motorglider 2G Soaring 0 September 20th 13 02:32 PM
IFR in motorglider? cp Soaring 28 March 9th 08 12:02 AM
Motorglider Tug Ray Lovinggood Soaring 21 November 13th 04 04:06 AM
motorglider KsiTau Soaring 0 September 4th 04 09:10 AM
