Best Overall Motorglider available today?
Old October 5th 20, 10:31 AM posted to rec.aviation.soaring
John Galloway[_2_]
Default Best Overall Motorglider available today?
The JS1 and ASH26 I used to fly were noticeably more roomy around the shoulders and upper arms than the V3M and I would be amazed if the JS2 wasn't similar. The Ventus Performance fuselage has a vertical side wall for a few inches below the cockpit rim whereas the JS gliders follow the Schleicher concept of a reinforcing inward curvature of the cockpit rim beneath which the shoulder and elbow-moving space is quite roomy. I wouldn't reject the JS2 on cockpit size alone without sitting in it first. Oscar Goudrian fits according to the picture on the JS FB page.
Old October 5th 20, 03:38 PM posted to rec.aviation.soaring
Carlo Orsini
JS2 spec:
Cockpit shoulder width
525 mm
ASH31Mi spec:
Cockpit width
660 mm
Yes, there is a photo of Goudriaan in the cockpit: his position is completely lying down with shoulders under the rims. I don't think you could fly 10 hours in that position IMHO.
When talking about aerodynamic drag the fuselage frontal area is an important factor, especially at high speeds (when induced drag is less).
A pilot must take a decision: top performance or compromise & comfort ? Both is simply impossible.
(This was a factor when I had to choose between ASH31Mi and Ventus2CxM)
Old October 5th 20, 05:22 PM posted to rec.aviation.soaring
John Galloway[_2_]
On Monday, 5 October 2020 at 15:38:53 UTC+1, Carlo Orsini wrote:
JS2 spec:
525 mm
ASH31Mi spec:
Cockpit width
660 mm
Those two dimensions for the JS2 and the ASH31 are clearly not be comparable - one internal cockpit rim and one external I guess. The 525mm shoulder width for the JS2 is exactly the same as the quoted figure for the JS1 (and JS3) and the JS1 cockpit roominess is fully equal to the ASH26/31 from which it was derived. I have 4 years in a JS1 followed by 2 in the ASH 26e and they are so similar that it would be hard to know which cockpit I was in with my eyes closed. Looking at the JS2 cockpit photographs it obvious that its structural cockpit rim design is the same as the 31, 26 and JS1. JS do not make small cockpits.
Old October 5th 20, 08:16 PM posted to rec.aviation.soaring
jfitch
It should not come as a surprise that the JS1/JS2 cockpits are similar to the ASH26, given that they took a splash mold off of a 26 fuselage to build them. They seem identical because they are.
JS2 spec:
525 mm
ASH31Mi spec:
Cockpit width
660 mm
Old October 5th 20, 08:55 PM posted to rec.aviation.soaring
John Galloway[_2_]
JS2 spec:
525 mm
ASH31Mi spec:
Cockpit width
660 mm
Indeed they are - as I said.
Old October 6th 20, 08:53 AM posted to rec.aviation.soaring
Carlo Orsini
Thank you for your first hand infos, those are good news for me (I don't understand why they advertise these dimensions in a different way). JS2 seems to be a nice project overall. Hard to me to understand where they streched out those +4 points of efficency in 21m, according to their calculated polars, compared to ASH31 (yes I know that '31 profiles are a bit superseeded and the aspect ratio is a factor too but 4 points are a huge amount!!).
Old October 6th 20, 04:39 PM posted to rec.aviation.soaring
jfitch
They are claiming 63:1, that is 7 points higher than AS claim of 56:1. I think it is best explained by a mistake in their math. I'd be interested in seeing the test data proving it.
Old October 6th 20, 06:08 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
The EB29 with 25M span is listed at 63, same as the 21 M span JS2. Four more
meters doesn't buy you what it used to!
jfitch wrote on 10/6/2020 8:39 AM:
Old October 6th 20, 10:37 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
[quote='Eric Greenwell[_4_];1030860']The EB29 with 25M span is listed at 63, same as the 21 M span JS2. Four more
Only a lower span loading
:-) Colin
Old October 6th 20, 06:45 PM posted to rec.aviation.soaring
Paul T[_4_]
th=
s=
eeing the test data proving it.=20
don't
JS2
see=
strech=
calculated
p=
superseede=
amount!!).
be
compa=
should=
JS1
from
26e
was
i=
obvious
th=
JS
I believe the Idafleig measured a JS1C at 63:1......so the JS2 witH its
few improvements on the JS1C should achieve that....
ASW 20C Motorglider Nick Kennedy[_3_] Soaring 3 February 7th 19 11:17 AM
FS: DG-400 Motorglider 2G Soaring 0 September 20th 13 02:32 PM
IFR in motorglider? cp Soaring 28 March 9th 08 12:02 AM
Motorglider Tug Ray Lovinggood Soaring 21 November 13th 04 04:06 AM
motorglider KsiTau Soaring 0 September 4th 04 09:10 AM
