Best Overall Motorglider available today?
Old November 19th 20, 05:01 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Best Overall Motorglider available today?
On Thu, 19 Nov 2020 08:23:43 -0800, Eric Greenwell wrote:
Dave Nadler wrote on 11/19/2020 6:59 AM:
On 11/19/2020 8:35 AM, Eric Greenwell wrote:
How odd the 63:1 only occurs at the high wing loading in 21M, and not
at the minimum wing loading, where the L/D is essentially the same for
the 18M and 21M wings.
Not odd at all. Reynolds number changes make a big difference
especially with tiny chord. IIRC the original Ventus 15m increased LD 2
points with ballast, and could not change wingloading as much as modern
gliders.
This does not seem to be about wing loading, as the chart shows the
18/21 versions at the same wing loading, so I repeat: It's still odd
that adding 10' to the span does not significantly change the
performance at any speed except in the lowest few knots of the polar.
If it's Reynolds number that's important: Shouldn't the 21 M wing have
more feet of wider chord than the 18M wing, and shouldn't we expect it
to do better, just based on that?
Aspect ratio is also beneficial and will increase the overall L/D ratio
at a given airspeed if the wing section and wing loading are unchanged.
Martin | martin at
Gregorie | gregorie dot org
Old November 20th 20, 07:02 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
How odd the 63:1 only occurs at the high wing loading in 21M, and not at the minimum wing
loading, where the L/D is essentially the same for the 18M and 21M wings.
Not odd at all. Reynolds number changes make a big difference especially with tiny chord. IIRC
the original Ventus 15m increased LD 2 points with ballast, and could not change wingloading as
much as modern gliders.
This does not seem to be about wing loading, as the chart shows the 18/21 versions at the same
wing loading, so I repeat: It's still odd that adding 10' to the span does not significantly
change the performance at any speed except in the lowest few knots of the polar.
If it's Reynolds number that's important: Shouldn't the 21 M wing have more feet of wider chord
than the 18M wing, and shouldn't we expect it to do better, just based on that?
The max wing loadings shown on the polar chart differ by c. 5 kg/m² so that fits with what is shown as does the equal min wing loadings
:-) Colin
Old November 20th 20, 07:25 AM posted to rec.aviation.soaring
Paul T[_4_]
At 12:13 19 November 2020, Paul T wrote:
For all you non-believers and skeptics that did not believe the JS1 had
been measured by the Idafleig at 63:1 please see the latest posting on th
Jonkers website regarding the JS2. Your really not as smart as you thin
you
are.
Apologies, should have said FB page(although the article should also be on
their website)- the article by Segelfleigen magazine on the JS2
acknowledges that Idafleig measured the JS1C at 63:1 as you where
previously informed off, but had to have a massive debate decrying the
fact.
Hopefully some of you have the intellect to read German.
Old November 20th 20, 01:46 PM posted to rec.aviation.soaring
James Metcalfe
the JS1 had
posting on the Jonkers website regarding the JS2. Your really
not as smart as you think you are.
also be on
fact.
Doubtless some of us, including some of the native English
speakers, *do* have the intellect to understand German. Had you
shown any aptitude for spelling, syntax and semantics, we might
have been more stung by your insulting tone.
I'll allow you the absurd "sKeptical", as I suppose that you
are American or Canadian. But not
"Idafleig" for "Idaflieg",
"Segelfleigen" for "Segelfliegen",
"Your really not ..." for "You're ...", and
"you where ... informed off" for "were" and "of" (which
latter should not have been dangling at the end of the clause).
Nor "non-believers and skeptics that ..." which, in addition to
the glaring tautology, was grammatically incorrect in using "that"
where "who" was required.
May I recommend the Biblical advice:
"First cast out the beam out of thine own eye"?
J.
Old November 20th 20, 02:09 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Paul T wrote on 11/19/2020 11:25 PM:
you
are.
fact.
I, like most of the people on this forum, do have the intellect to read German, but not the
training or the motivation. Why not translate crucial paragraph(s) for us?
Old November 20th 20, 03:38 PM posted to rec.aviation.soaring
John Galloway[_2_]
Leaving aside the grammar squabble, why the hang-up about the best L/D Mr T? Modern competition gliders are designed for good climbing and good inter-thermal cruising performance. If the bit of the polar in between turns out to give a high best L/D figure all well and good, but when should such a glider be flown at best L/D? Hardly ever - and if anyone is hoping that best L/D is maybe going to get them home when a higher MC setting final glide won't then they need to have a good think about the implications and possible consequences of that.
Best motor-glider? As an ex-owner of a JS1C 18/21 I was very keen to get a JS2 but it has taken too long in development, I didn't really want the 21m tips without which it probably wouldn't be very salable, (Oxford comma) and the JS3 and pending JS5 will outgun it in the 18m and Open classes respectively. I am pretty happy with the Ventus 3M.
John Galloway
you
are.
fact.
ASW 20C Motorglider Nick Kennedy[_3_] Soaring 3 February 7th 19 11:17 AM
FS: DG-400 Motorglider 2G Soaring 0 September 20th 13 02:32 PM
IFR in motorglider? cp Soaring 28 March 9th 08 12:02 AM
Motorglider Tug Ray Lovinggood Soaring 21 November 13th 04 04:06 AM
motorglider KsiTau Soaring 0 September 4th 04 09:10 AM
