Best Overall Motorglider available today?
Old November 19th 20, 04:23 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Best Overall Motorglider available today?
Dave Nadler wrote on 11/19/2020 6:59 AM:
On 11/19/2020 8:35 AM, Eric Greenwell wrote:
How odd the 63:1 only occurs at the high wing loading in 21M, and not at the minimum wing
loading, where the L/D is essentially the same for the 18M and 21M wings.
Not odd at all. Reynolds number changes make a big difference especially with tiny chord. IIRC
the original Ventus 15m increased LD 2 points with ballast, and could not change wingloading as
much as modern gliders.
This does not seem to be about wing loading, as the chart shows the 18/21 versions at the same
wing loading, so I repeat: It's still odd that adding 10' to the span does not significantly
change the performance at any speed except in the lowest few knots of the polar.
If it's Reynolds number that's important: Shouldn't the 21 M wing have more feet of wider chord
than the 18M wing, and shouldn't we expect it to do better, just based on that?
Old November 19th 20, 05:01 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
at the minimum wing loading, where the L/D is essentially the same for
especially with tiny chord. IIRC the original Ventus 15m increased LD 2
points with ballast, and could not change wingloading as much as modern
gliders.
18/21 versions at the same wing loading, so I repeat: It's still odd
that adding 10' to the span does not significantly change the
more feet of wider chord than the 18M wing, and shouldn't we expect it
Aspect ratio is also beneficial and will increase the overall L/D ratio
at a given airspeed if the wing section and wing loading are unchanged.
Martin | martin at
Gregorie | gregorie dot org
Old November 19th 20, 06:31 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Martin Gregorie wrote on 11/19/2020 9:01 AM:
gliders.
Exactly! And yet, despite an aspect ratio of 36 (21 M) vs 29 (18 M), the 21 M performance is
almost identical, according to the chart. How can that be?
Old November 19th 20, 10:23 PM
Brett Brett is offline
Member
First recorded activity by AviationBanter: May 2006
https://sites.google.com/site/motorg...ad-the-guide-1[/quote]
Hi - The polar graph on the JS website starts at a higher airspeed than most others - the major performance difference between spans occurs around the thermalling speed region which is missing in the graph. I can attest from flying JS1's in both spans against others that there is very little noticable performance difference at similar wingloadings at cruise speeds.
That said I believe the ballasted 21m JS1 is an underrated weapon and the JS2 will be even better. The JS5 will be in a class of its own.
Old November 20th 20, 07:02 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
The max wing loadings shown on the polar chart differ by c. 5 kg/m² so that fits with what is shown as does the equal min wing loadings
:-) Colin
ASW 20C Motorglider Nick Kennedy[_3_] Soaring 3 February 7th 19 11:17 AM
FS: DG-400 Motorglider 2G Soaring 0 September 20th 13 02:32 PM
IFR in motorglider? cp Soaring 28 March 9th 08 12:02 AM
Motorglider Tug Ray Lovinggood Soaring 21 November 13th 04 04:06 AM
motorglider KsiTau Soaring 0 September 4th 04 09:10 AM
