What is involved regulation wise adding an electric motor to a glider?
Old February 3rd 21, 11:10 PM posted to rec.aviation.soaring
Mark Mocho
Default What is involved regulation wise adding an electric motor to a glider?
Not to hijack the thread, but in response to the reliability issue of two-stroke engines, the primary culprit seems to be the different altitudes at which the engine is supposed to start and operate. The fuel/oil/air mixture has to be within certain parameters for decent running and starting reliability. An increase in altitude (or high density altitude conditions) reduces the amount of available oxygen, which contributes to fouling the spark plugs. I used to ride the Yamaha RD-350 and TZ-250 motorcycles from Albuquerque (elevation ~5,500 ft. MSL) up to Sandia Crest (10,678 ft. MSL) and used to have to stop and adjust the needles in the carburetors four times on the way up and four times on the way down or risk plug fouling or overheating and possibly seizing the engine. About a 1,000 ft. change in altitude was all it took to affect the performance and reliability. Newer two-stroke engines with more sophisticated fuel injection systems seem to be much more reliable in motorgliders.
Old February 4th 21, 04:36 AM posted to rec.aviation.soaring
Wallace Berry[_2_]
Oh, that brings back memories. I too rode an RD-350 (voted as the "Bike most likely to lose you your driver's license"). Even tried production class road racing on it a couple times (scary). Had the same experience as you with riding in the mountains. Used to stop on the way up to Deal's Gap and drop the carb needles a notch. Put 38,000 miles on the bike. Never failed to start and run. Stopped being scooter trash and became glider trash, but still have that bike (mothballed since 1981).
Old February 4th 21, 04:51 PM posted to rec.aviation.soaring
Dan Marotta
Default What is involved regulation wise adding an electric motor to aglider?
Talk about hijacking...
I've had my Harley Davidson Wide Glide for almost 17 years and 137,000
miles and don't ride it too much any more though I did get it out a
couple of days ago when the temperature got up to 60 deg. Just
wondering what you did to mothball it. I've never done more than to put
on a battery charger now and then.
Dan
5J
Old February 4th 21, 08:13 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
Dan
5J
Drained the transmission case and replaced with fresh oil. Drained the fuel tank, lines, carbs. Flushed everything with clean fuel and stabilizer, then drained again and let dry before reassembly. Drained the forks and replaced the fork fluid. Drained the front brake hydraulics. Fogged the cylinders with Marvel Mystery Oil and turned them over a few times. Threw the battery away. Heavily Armor All'ed the exterior rubber and vinyl. Probably should have used products expressly made to pickle engines, but I didn't know I was going to keep the bike stored for 40 years. Front fork wipers, brake lines, and tires have deteriorated. Everything else seems OK. RD 350's were still being made (in India) up into the late 1990's or early 2000's so parts are still available. Hoping to do a complete restoration as a retirement project, but I don't plan on taking up riding scooters again. Old bones and all...
Old February 4th 21, 11:36 PM posted to rec.aviation.soaring
Dan Marotta
Thanks!
Took mine to the store today and it was too cold for me. Temperature in
the 40s. Put her back to sleep...
Dan
5J
Dan
5J
Old February 6th 21, 01:31 AM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, February 3, 2021 at 3:10:11 PM UTC-8, Mark Mocho wrote:
...I used to ride the Yamaha RD-350 and TZ-250 motorcycles...
I raced RD-250 in 250 Modified Production and TA-125 in GP classes during my mis-spent youth. Fun stuff, but there is no way I'd trust my life to the continued operation of a tightly-wound two-stroke motor. I didn't think I'd mess around with motorgliders at all until brushless motors and Lithium batteries came along. Now I think that electric motorgliders are poised to become the core of our sport, with pure sailplanes becoming more of a fringe activity.
Old February 7th 21, 06:18 PM posted to rec.aviation.soaring
kinsell
if you're trusting your life to the operation of any motorglider engine,
you're screwing up bigtime. Electrics can and do fail, right along with
the others.
A B-52H Nicknamed "Wise Guy" Becomes The Second To Ever Come Back From The Bone Yard [1/5] - note on the panel inside Wise Guy.jpg (1/1) Miloch Aviation Photos 0 May 15th 19 03:46 AM
Pilotless Electric Motor Glider Generates Clean Power Mike Mike Ground Soaring 0 November 27th 11 06:27 PM
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
electric motor? solarsell Home Built 13 January 12th 07 12:03 AM
Question about adding a second electric AI M Owning 10 January 4th 05 07:29 PM
