What is involved regulation wise adding an electric motor to a glider?
Old February 8th 21, 08:22 PM posted to rec.aviation.soaring
Dan Marotta
Default What is involved regulation wise adding an electric motor to aglider?
I spoke with Luka about 5 years ago about installing FES in my LAK-17a.
There are plenty of very competent folks at Moriarty to do the work, but
Luka was firm that only he and his people would do it. He said that for
roughly $25K each for a minimum of 4 gliders, plus travel and living
expenses, they'd come to the US and do the work. I got a Stemme, instead.
Dan
5J
On 2/8/21 11:20 AM, David Scott wrote:
On Sunday, February 7, 2021 at 9:41:30 PM UTC-8, Nicholas Kennedy wrote:
David Scott
I don't know what your budget is.. But If you want to work on a electric glider a good choice might be to get a Antares.
From what I've read their very high performance, very nice to fly, but need ALOT of hands on work to keep them running.
Building something from scratch sounds very daunting to me.
JJ's post above is a eye opener.
Hanks posts are too. He's a full time professional in the Glider Biz, and look at the hurtles and challenges he had to overcome.
It seems to me you could easily spend a bunch of money, get in way over your head and end up with a very expensive, unflyable, unsafe, un airworthy, piece of junk.
Good Luck!
Nick
T
Nicholas, I am on the very low scale of budget now, which is why I am looking at the cheapest options, but expect the future will improve. To be clear, I will not cut up a good glider and not finish the project. Touching a glider would be the last part, after the power module is fully working and debugged on the bench. I fully understand it is not a small project. This really isn't a hard project there are many ways to accomplish it. I have embarked on bigger ones without knowing how to solve all of the problems involved, and failed at one. I have enough experience not to fail at a project like this.
John, this is something I have kept in mind. I am 165lbs dressed and can lose 10 with no problem, and should. I also think I could keep a power setup well under 100 lbs.
The FES distributor I found is indeed Blanik America.
Here is an interesting video showing the difference of a small prop vs a larger prop with gear reduction. Other than that the complete drive system is the same.
Small prop is 26kg of thrust @ 168 amps, large prop is 40kgs of thrust @ 138 amps. The video is https://www.youtube.com/watch?v=WgNMc35zqYo&t=154s.
Kenn, I PMed you about joining your Slack group, thank you. As for the drag of the pylon, yes, that is a big issue and one that going electric could really make a difference on. I think the unit that GP Gliders uses is the only one that tries to reduce the drag. The Grasshopper unit really fails in this regard, but wouldn't be hard to fix later on.
Thank you to J. and Kenn for the drag numbers, that is very informative. It looks like 110lbs of thrust would perhaps work pretty well. This is kind of the low end for electric paramotors and they don't operate on a streamlined pylon.
At the moment I am really liking the idea of a custom retractable pylon module and steal the rest from a paramotor to take advantage of their scale of economy and leverage what developments they make. This also means using a fixed 60" 2 blade propeller for improved efficiency. Or the closest I can get to match the motor used.
Hank, I already said I didn't think the FES system was viable for what I am looking for and fully understand why they would want nothing to do with it for the reasons you mention. As a machine shop I deal with it too. Thanks for the $$$$ info, looks like I was close but a little low.
Dan, seveal electric gliders store the batteries in the wings. I think the Antares does and know the GP Gliders do. I wonder how viable that would be for a retrofit? I also wonder how Antares and GP deal with thermal stability and fire control in the wings?
A B-52H Nicknamed "Wise Guy" Becomes The Second To Ever Come Back From The Bone Yard [1/5] - note on the panel inside Wise Guy.jpg (1/1) Miloch Aviation Photos 0 May 15th 19 03:46 AM
Pilotless Electric Motor Glider Generates Clean Power Mike Mike Ground Soaring 0 November 27th 11 06:27 PM
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
electric motor? solarsell Home Built 13 January 12th 07 12:03 AM
Question about adding a second electric AI M Owning 10 January 4th 05 07:29 PM
