On Tuesday, February 9, 2021 at 7:21:05 AM UTC-8, Dan Marotta wrote:
That's really great! I wonder, however... Are they also setting up the infrastructure? How many airports have hydrogen? If I chose to carry my own, where would I get it? Seriously, I think fuel cells are a better way to go for electrics, but where does the fuel come from? In a reasonable amount of time. Dan 5J On 2/8/21 8:37 PM, Darren Braun wrote: Pipistrel is working on a hydrogen fuel cell powered aircraft. This might be an interesting idea to consider. I have heard of another company working on a larger 6 person aircraft that recently took flight. https://www.compositesworld.com/news...t-takes-flight Darren Eric, Installing an electric propulsion system involves a good deal more weight than just the motor and battery weight. There must be battery cables large enough to carry hundreds of amps + controller+ motor mount+ propeller + spinner and a fire resistant battery box? Hank Nixon has made such an instillation and he said it weighed an additional 100#...........I’ll take Hanks figure! As for “backing off of the red-line”, if you exceed the maximum weight of non lifting surfaces............your Experimental Airworthiness Certificate, contains the following.........This aircraft will be operated in accordance with the Flight Manual and maintained in accordance with the Maintenance Manual! I’d hate to hear that read to me by an insurance lawyer in court, some day! JJ |
John Sinclair wrote on 2/9/2021 11:48 AM:
Eric, Installing an electric propulsion system involves a good deal more weight than just the motor and battery weight. There must be battery cables large enough to carry hundreds of amps + controller+ motor mount+ propeller + spinner and a fire resistant battery box? Hank Nixon has made such an instillation and he said it weighed an additional 100#...........Ill take Hanks figure! As for backing off of the red-line, if you exceed the maximum weight of non lifting surfaces............your Experimental Airworthiness Certificate, contains the following.........This aircraft will be operated in accordance with the Flight Manual and maintained in accordance with the Maintenance Manual! Id hate to hear that read to me by an insurance lawyer in court, some day! JJ Was it 100 lbs for the total system, including the mast? Or just the stuff he added to the ASW24E? Ken is using a Russia 5, which already has a motor & mast in it, so he's removing the gas engine, and adding an electric motor - that's probably the same net weight, or less. The batteries will add a lot of weight (maybe 30 lbs, given the Kwh Kenn wants); the controllers, and cables with add some more, but it seems unlikely it will exceed 60 lbs. If it's experimental, surely the owner/modifier gets to acquire a new Airworthiness certificate, and change the flight manual to match the changes he's made in the aircraft? It wouldn't make sense to require Hank to adhere to the flight manual for an ASW24E (gas sustainer engine) after he's made it into an electric self-launcher, for example. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Tuesday, February 9, 2021 at 3:58:12 PM UTC-5, Eric Greenwell wrote:
John Sinclair wrote on 2/9/2021 11:48 AM: Eric, Installing an electric propulsion system involves a good deal more weight than just the motor and battery weight. There must be battery cables large enough to carry hundreds of amps + controller+ motor mount+ propeller + spinner and a fire resistant battery box? Hank Nixon has made such an instillation and he said it weighed an additional 100#...........I’ll take Hanks figure! As for “backing off of the red-line”, if you exceed the maximum weight of non lifting surfaces............your Experimental Airworthiness Certificate, contains the following.........This aircraft will be operated in accordance with the Flight Manual and maintained in accordance with the Maintenance Manual! I’d hate to hear that read to me by an insurance lawyer in court, some day! JJ Was it 100 lbs for the total system, including the mast? Or just the stuff he added to the ASW24E? Ken is using a Russia 5, which already has a motor & mast in it, so he's removing the gas engine, and adding an electric motor - that's probably the same net weight, or less. The batteries will add a lot of weight (maybe 30 lbs, given the Kwh Kenn wants); the controllers, and cables with add some more, but it seems unlikely it will exceed 60 lbs. If it's experimental, surely the owner/modifier gets to acquire a new Airworthiness certificate, and change the flight manual to match the changes he's made in the aircraft? It wouldn't make sense to require Hank to adhere to the flight manual for an ASW24E (gas sustainer engine) after he's made it into an electric self-launcher, for example. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The net change for my '24E was 2 lb increase compared to condition before change, weighed without fuel. Battery weighs 60 lb, 120V 5.75kwh. Motor weighs 18 lb Controller weighs 4-1/2 2 batteries in the nose. 12 lb The 100 lb comparison I made is my 24E compared to a pure glider. This reflects the above plus structural changes between 24 and 24E as well as the lift mechanism. UH |
Hank Nixon wrote on 2/9/2021 1:29 PM:
On Tuesday, February 9, 2021 at 3:58:12 PM UTC-5, Eric Greenwell wrote: John Sinclair wrote on 2/9/2021 11:48 AM: Eric, Installing an electric propulsion system involves a good deal more weight than just the motor and battery weight. There must be battery cables large enough to carry hundreds of amps + controller+ motor mount+ propeller + spinner and a fire resistant battery box? Hank Nixon has made such an instillation and he said it weighed an additional 100#...........Ill take Hanks figure! As for backing off of the red-line, if you exceed the maximum weight of non lifting surfaces............your Experimental Airworthiness Certificate, contains the following.........This aircraft will be operated in accordance with the Flight Manual and maintained in accordance with the Maintenance Manual! Id hate to hear that read to me by an insurance lawyer in court, some day! JJ Was it 100 lbs for the total system, including the mast? Or just the stuff he added to the ASW24E? Ken is using a Russia 5, which already has a motor & mast in it, so he's removing the gas engine, and adding an electric motor - that's probably the same net weight, or less. The batteries will add a lot of weight (maybe 30 lbs, given the Kwh Kenn wants); the controllers, and cables with add some more, but it seems unlikely it will exceed 60 lbs. If it's experimental, surely the owner/modifier gets to acquire a new Airworthiness certificate, and change the flight manual to match the changes he's made in the aircraft? It wouldn't make sense to require Hank to adhere to the flight manual for an ASW24E (gas sustainer engine) after he's made it into an electric self-launcher, for example. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The net change for my '24E was 2 lb increase compared to condition before change, weighed without fuel. Battery weighs 60 lb, 120V 5.75kwh. Motor weighs 18 lb Controller weighs 4-1/2 2 batteries in the nose. 12 lb The 100 lb comparison I made is my 24E compared to a pure glider. This reflects the above plus structural changes between 24 and 24E as well as the lift mechanism. UH So, motor battery weighs 60 lbs, but what are the 12 lbs of battery in the nose? Do you remember the motor power wire size and weight? How was your airworthiness certificate, Flight manual, and Maintenance manual affected by the new power source? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Tuesday, February 9, 2021 at 5:06:42 PM UTC-5, Eric Greenwell wrote:
Hank Nixon wrote on 2/9/2021 1:29 PM: On Tuesday, February 9, 2021 at 3:58:12 PM UTC-5, Eric Greenwell wrote: John Sinclair wrote on 2/9/2021 11:48 AM: Eric, Installing an electric propulsion system involves a good deal more weight than just the motor and battery weight. There must be battery cables large enough to carry hundreds of amps + controller+ motor mount+ propeller + spinner and a fire resistant battery box? Hank Nixon has made such an instillation and he said it weighed an additional 100#...........I’ll take Hanks figure! As for “backing off of the red-line”, if you exceed the maximum weight of non lifting surfaces............your Experimental Airworthiness Certificate, contains the following.........This aircraft will be operated in accordance with the Flight Manual and maintained in accordance with the Maintenance Manual! I’d hate to hear that read to me by an insurance lawyer in court, some day! JJ Was it 100 lbs for the total system, including the mast? Or just the stuff he added to the ASW24E? Ken is using a Russia 5, which already has a motor & mast in it, so he's removing the gas engine, and adding an electric motor - that's probably the same net weight, or less. The batteries will add a lot of weight (maybe 30 lbs, given the Kwh Kenn wants); the controllers, and cables with add some more, but it seems unlikely it will exceed 60 lbs. If it's experimental, surely the owner/modifier gets to acquire a new Airworthiness certificate, and change the flight manual to match the changes he's made in the aircraft? It wouldn't make sense to require Hank to adhere to the flight manual for an ASW24E (gas sustainer engine) after he's made it into an electric self-launcher, for example.. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The net change for my '24E was 2 lb increase compared to condition before change, weighed without fuel. Battery weighs 60 lb, 120V 5.75kwh. Motor weighs 18 lb Controller weighs 4-1/2 2 batteries in the nose. 12 lb The 100 lb comparison I made is my 24E compared to a pure glider. This reflects the above plus structural changes between 24 and 24E as well as the lift mechanism. UH So, motor battery weighs 60 lbs, but what are the 12 lbs of battery in the nose? Do you remember the motor power wire size and weight? How was your airworthiness certificate, Flight manual, and Maintenance manual affected by the new power source? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Nose batteries power left as in original powering the lift and instruments and help with CG. Motor wires are double 10 ga high conductive wire on each phase. There is a lot of wire but I don't think it is a major weight contributor. I got a new AW certificate. I rewrote manual pages and operating limitations where they were affected. Feds spent about 2 minutes looking at all that.. UH |
Hank Nixon wrote on 2/9/2021 1:29 PM: On Tuesday, February 9, 2021 at 3:58:12 PM UTC-5, Eric Greenwell wrote: John Sinclair wrote on 2/9/2021 11:48 AM: Eric, Installing an electric propulsion system involves a good deal more weight than just the motor and battery weight. There must be battery cables large enough to carry hundreds of amps + controller+ motor mount+ propeller + spinner and a fire resistant battery box? Hank Nixon has made such an instillation and he said it weighed an additional 100#...........I’ll take Hanks figure! As for “backing off of the red-line”, if you exceed the maximum weight of non lifting surfaces............your Experimental Airworthiness Certificate, contains the following.........This aircraft will be operated in accordance with the Flight Manual and maintained in accordance with the Maintenance Manual! I’d hate to hear that read to me by an insurance lawyer in court, some day! JJ Was it 100 lbs for the total system, including the mast? Or just the stuff he added to the ASW24E? Ken is using a Russia 5, which already has a motor & mast in it, so he's removing the gas engine, and adding an electric motor - that's probably the same net weight, or less. The batteries will add a lot of weight (maybe 30 lbs, given the Kwh Kenn wants); the controllers, and cables with add some more, but it seems unlikely it will exceed 60 lbs. If it's experimental, surely the owner/modifier gets to acquire a new Airworthiness certificate, and change the flight manual to match the changes he's made in the aircraft? It wouldn't make sense to require Hank to adhere to the flight manual for an ASW24E (gas sustainer engine) after he's made it into an electric self-launcher, for example.. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The net change for my '24E was 2 lb increase compared to condition before change, weighed without fuel. Battery weighs 60 lb, 120V 5.75kwh. Motor weighs 18 lb Controller weighs 4-1/2 2 batteries in the nose. 12 lb The 100 lb comparison I made is my 24E compared to a pure glider. This reflects the above plus structural changes between 24 and 24E as well as the lift mechanism. UH So, motor battery weighs 60 lbs, but what are the 12 lbs of battery in the nose? Do you remember the motor power wire size and weight? How was your airworthiness certificate, Flight manual, and Maintenance manual affected by the new power source? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Nose batteries power lift and instruments and help with CG as original Motor wires are double 10 ga high conductive for each phase . Not all that much weight I rewrote manual pages and operating limitations . Feds spent about 2 minutes on that and used all my stuff. UH |
Battery weighs 60 lb, 120V 5.75kwh. Motor weighs 18 lb Controller weighs 4-1/2 2 batteries in the nose. 12 lb The 100 lb comparison I made is my 24E compared to a pure glider. This reflects the above plus structural changes between 24 and 24E as well as the lift mechanism. UH Thanks for those figures. I've calculated similarly tiny net changes in weight for an electric conversion-- on paper, I should wind up all of 500g lighter. Of course, the reality won't perfectly track the numbers, but it's heartening to see my hunch played out in your case. |
A B-52H Nicknamed "Wise Guy" Becomes The Second To Ever Come Back From The Bone Yard [1/5] - note on the panel inside Wise Guy.jpg (1/1) | Miloch | Aviation Photos | 0 | May 15th 19 03:46 AM |
Pilotless Electric Motor Glider Generates Clean Power | Mike Mike Ground | Soaring | 0 | November 27th 11 06:27 PM |
Electric motor for hang glider | Legend Length | Home Built | 11 | August 27th 09 02:14 AM |
electric motor? | solarsell | Home Built | 13 | January 12th 07 12:03 AM |
Question about adding a second electric AI | M | Owning | 10 | January 4th 05 07:29 PM |
