Vc gear difficulty
Old April 5th 21, 05:51 PM posted to rec.aviation.soaring
John Galloway[_2_]
Default Vc gear difficulty
On Monday, 5 April 2021 at 17:07:05 UTC+1, John Sinclair wrote:
On Monday, April 5, 2021 at 7:54:36 AM UTC-7, Phoenix wrote:
On Monday, April 5, 2021 at 10:46:55 AM UTC-4, Richard Pfiffner wrote:
On Monday, April 5, 2021 at 4:49:19 AM UTC-7, Phoenix wrote:
Anyone have a solution as to why my gear is so VERY difficult to retract / extend on my Ventus c? It's the very last 10% trying to get the lever into the indent that's the problem.
Also check that the bolts and nuts for the gear are not too tight and are well lubricated. This may happen if the gear has be removed and reinstalled. If you continues to pull/Push on an overly tight gear handle good chance that the handle may break off.
How do I know this????
Richard
www.craggyaero.com
Don’t neglect to lube the gear door hinges, I’ve seen them so stiff that it’s hard to move by hand! Also, check the new tire To verify its the brand and style called out in the manual.......not all tire styles will fit into your wheel well (round face, not squared off)
It’s very hard to get to all the lube points with the fuselage upright, if possible, remove the canopy and lift the fuselage up onto saw-horses. Then roll it 90 degrees left and then right in order to clean, lube and inspect all moving parts! Move the gear up and down while observing the wheel well and doors............problem should become obvious. Many gears have springs that assist in lifting the gear.....check for broken/missing springs?
Good luck,
JJ
I have found with several SH gliders that apart from the heaviness of lifting the gear there are 2 other issues. Firstly if you pull the handle too fast it bounces forward off the back stop so won't go in the detent. Secondly, when the handle is held in the natural thumb up position the thickness of the knuckles stops the handle from being held vertically enough to get fully into the detent. I invert my grip, which keeps the handle closer to the wall, and I try to retract smoothly while pushing the handle towards the cockpit wall.
Old April 5th 21, 06:10 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Galloway wrote on 4/5/2021 9:51 AM:
Richard
www.craggyaero.com
Good luck,
JJ
John describes the situation and most of the procedure many of the ASH26E pilots use. The rest
of the procedu push over gently (some forward stick) as you move the handle back, which
lightens the load on the gear handle, making it easy(ier) to move into the detent. No need to
go "zero G", just push over a little bit. It may take a few tries the first time, but you'll
quickly get the timing right.
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 November 12th 18 01:49 PM
ASW 28 Service Difficulty Report Andy[_1_] Soaring 2 May 4th 11 07:40 PM
Difficulty in posting to r.a.s. delboy Soaring 7 November 7th 09 08:15 PM
iPAQ Touchscreen Difficulty jcarlyle Soaring 6 August 20th 09 02:34 AM
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
