Matt
I suspect that the colorant in ABS is carbon black. Make sure there is little to no carbon content, which would seriously alter antenna and system performance. BLACK anything -- including plastics -- is usually the worst, as they often have high carbon content. Think of applying black paint with carbon in it as applying very thin, black tin foil. Would you do that? Of course not. It would be both a shield and reflector, both of which are bad for the antenna (shield), the system connected to it (reflected power, VSWR, etc.), not to mention system performance. Richard www.craggyaero.com |
Flarm Range Analysis | Dan Marotta | Soaring | 22 | June 16th 17 10:54 AM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
FLARM Range | [email protected] | Soaring | 11 | June 16th 15 11:44 PM |
Flarm range | Ramy[_2_] | Soaring | 7 | May 7th 15 11:02 PM |
long range aircraft flying short-range routes? | tupolev204 | Piloting | 10 | April 22nd 11 07:44 PM |
