"John Miller" wrote in message ... Dudley Henriques wrote: Thanks much Pete. This training manual supposedly says that the 51 can't hold a slip due to aileron or rudder issues that make it straighten out if the pilot tries to hold it in a slip. I've done hundreds of slips to both sides in this airplane and never had such an issue. I'm assuming the training manual was written as an aid in transitioning low time pilots into the high performance 51, as the dash one specifically states that slips are not an issue. Just guessing here -- if a slip (in the P51) approaches a stall, is its behavior particularly treacherous? Any aircraft, whether in a slip or not, that approaches it's critical angle of attack (stall) can be dangerous if close to the ground. Slips are not done at AOA close to stall. AOA is controlled in a slip by pitch the same way it is in non cross controlled flight. The Mustang, having a laminar wing can stall more quickly than say an aircraft with a higher cambered wing. To eliminate pilots bending the sheet metal, it is usually recommended that slips in the 51 end at or above 200 feet AGL. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
| Thread Tools | |
| Display Modes | |
| Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 09:34 PM |
| Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 06:49 PM |
| aero-domains for homebuilt experts | secura | Home Built | 0 | June 26th 04 08:11 AM |
| JASPO Experts On Civil Aircraft Survivability | sid | Military Aviation | 2 | February 13th 04 08:41 AM |
| Aircraft Id needed from newsgp experts! | RGP | Military Aviation | 1 | January 1st 04 08:15 PM |
