Any P51 experts out here?
Old February 10th 05, 02:30 PM
John Miller
Dudley Henriques wrote:
The Mustang, having a
laminar wing can stall more quickly than say an aircraft with a higher
cambered wing.
To eliminate pilots bending the sheet metal, it is usually recommended
that slips in the 51 end at or above 200 feet AGL.
That was kind of my question, which I probably phrased poorly, that is,
wouldn't the laminar wing give significantly less warning pre-departure
compared with, oh, say, a Stearman, which lots of the WWII guys learned
to slip in? I believe you said that you'd done slips in a Mustang,
which shows it *can* be slipped, and suggests that the warning may be
more cautionary than indicative of a technical difficulty.
Best regards,
John Miller, who doesn't like to do slips in ANY aircraft below 200'
AGL, actually...
Old February 10th 05, 02:37 PM
Dudley Henriques
"John Miller" wrote in message
higher cambered wing.
recommended that slips in the 51 end at or above 200 feet AGL.
is, wouldn't the laminar wing give significantly less warning
pre-departure compared with, oh, say, a Stearman, which lots of the
WWII guys learned to slip in? I believe you said that you'd done
slips in a Mustang, which shows it *can* be slipped, and suggests that
the warning may be more cautionary than indicative of a technical
difficulty.
Best regards,
AGL, actually...
You are correct about the Stearman/ Mustang comparison. The 51 is best
put on the mains tail low, at least that has always been my
recommendation and practice.
I agree about the training manual, and expect that is what will be
discovered as I research this a bit more.
DH
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 7 November 6th 04 08:34 PM
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 05:49 PM
aero-domains for homebuilt experts secura Home Built 0 June 26th 04 07:11 AM
JASPO Experts On Civil Aircraft Survivability sid Military Aviation 2 February 13th 04 07:41 AM
Aircraft Id needed from newsgp experts! RGP Military Aviation 1 January 1st 04 07:15 PM
