![]() "Peter Stickney" wrote in message ... In article t, "Dudley Henriques" writes: Thanks much Pete. That's the exact quote I was getting on this, so this has to be the training manual in question. I asked around the P51 community a bit on this and have heard back from Vlado Lenoch and Glenn Wegman. Neither mentioned the manual per se, but not to my surprise, agreed with me that there are no basic issues in slipping the 51 save doing it below 200 feet due to the quick and sometimes unpredictable payoff behavior of the wing at low speed and high angles of attack. Thanks. Back when Don Davidson had his Mustang, he told me that he had no problems at all with anything he wanted to do with it. (I know - that's a somewhat loaded statement, but he's practice aerobatics over my house, so it wasn't all straight and level.) The stability and control derivitives from the NACA documents indicate that there shouldn't be any problems, either. My thoughts exactly. When I was told about this being in this manual, I immediately dove into my dusty old desk and dug out the old dash 1 for my airplane. Under rudder control, it plainly states that sideslips are no issue at all, and in fact mentions sideslips by name. My take on the training manual is that pilots coming out of Advance in the AT6 and transitioning into 51's during lead in fighter training were faced with dealing with the laminar characteristics of the Mustang coming off the comparatively higher lift characteristics of the T6, which could be slipped like mad. I'm fairly certain, although I could never prove this, that the Training Command thinking at the time was to save lives and conserve sheet metal. The Mustang really doesn't need to be slipped on final due to the extremely high drag of the last flap position at 50 degrees (47 actually) plus running up the prop to low pitch against the stops is like dragging your feet in the mud in this airplane. My guess is that ATC just decided after looking at the log books for total time of the guys transitioning into the Mustang that having this restriction saved them a lot of trouble writing accident reports, since it wasn't necessary to slip the airplane anyway. The wording is interesting though, and I guess one could stretch a point in justifying the restriction by noting control response degradation in the left side of the Mustang's envelope. That makes a lot of sense, from a Peacetime Air Force point of view. I've heard similar tales about the F-86. Apparantly the Word Went Down in ATC that F-86s couldn't be slipped, while pilots all over the world were slipping them in on final. North American actually sent Hoover out to the groups to show the guys what they could do with the F86. Then they sent him out again in the F100 to do the same thing. The guys were blowing tires on landings. Bob slipped and skidded the damn things all over the sky. When he was finished, everyone knew what could and couldn't be done in these airplanes. :-)) I think the only airplane Bob hasn't done these one wheel landings in was the day I loaned him Miss America at Transpo when his 51 was down after a gear malfunction. Howie asked me to ask Bob NOT to one wheel Miss A, as we thought it placed a possible side load on the main strut and Howie had to pay for the maintainence as opposed to Rockwell footing any bills for Bob stressing a strut once in a while :-)) About the military/civvie conversions; Mine had the old radios and junk in it. The military Mustang had a bunch of crap in it that more or less kept the cg in limits. When the guys started gutting them and converting them, they took a lot out and threw the cg forward enough that they needed weight in the tail or at least had to be REAL careful landing them. It wasn't uncommon to see full nose up pitch trim on some of them after 3 pointing them. To tell you the truth, that seems more than a bit dicey to me. Wasn't anybody doing Weights & Balances on them? Throwing the CG out to make room for more stuff sounds like a disaster in the making. Especially if the pilot's new to the airplane, and new to high performance airplanes in general. Actually, the problem was taking the stuff out!!! It threw the cg FORWARD. The guys were putting weights in the tails to get the moments in the right place. The civilian conversions were LIGHTER than the military airplane. If you flew a civilian Mustang, the landing behavior was different. You could be feeding in a lot of back trim on final with all that weight out of there. :-)) I always landed the Mustang with some speed on the airplane, tail low on the mains anyway, but the cg can be a problem for the pilots who like to do 3 pointers in the airplane. Oddly enough, the L-19 was the same way for me. I couldn't 3-point the blasted thing for beans, but a tail-low wheeler was the most comfortable. Putting that little bird down on the mains with that spring gear had it's moments that's for sure :-)) I remember Vlado telling me something about Moonbeam's configuration, but I forget if he has the cg issue. I would assume he does, as Collins, Bendix, and King, are a whole lot lighter than that old crap we had in there :-)) Dudley I guess the bottom line on what the manual says would be; Manual says "no slips" Dash 1 says, "No slip restrictions" I would say, "no problem at all, but not under 200 feet" Other P51 pilots are checking in with "I do it" Puzzling how the government does things isn't it? :-)))) I've seen worse. Thanks loads for taking the time for this info. Knowing where it came from is a lot of help. Dudley |
Dudley,
Let me start out by saying that I'm not a pilot and have never flown anything with more power than a T-34A (flown from the backseat with a "real pilot" up front) and a P-3 from the right seat. Would the sideslip issue have been affected by the addition of the fairing forward of the vertical stab? IIRC the P-51B/Cs didn't need the fairing because of the extra side area they had compared to the D-model. The early D-models apparently did have directional stability issues prior to addition of the fairing. Maybe the training manual came out before it was added? Don McIntyre Clarksville, TN |
![]() "Don McIntyre" wrote in message oups.com... Dudley, Let me start out by saying that I'm not a pilot and have never flown anything with more power than a T-34A (flown from the backseat with a "real pilot" up front) and a P-3 from the right seat. Would the sideslip issue have been affected by the addition of the fairing forward of the vertical stab? IIRC the P-51B/Cs didn't need the fairing because of the extra side area they had compared to the D-model. The early D-models apparently did have directional stability issues prior to addition of the fairing. Maybe the training manual came out before it was added? Don McIntyre Clarksville, TN That's an astute observation and is correct about the airplane. The post block 10 D's did have a dorsal added for improved directional stability. It's always been my understanding that this was due to airflow issues coming off the bubble canopy changeover, but I ran into a NA engineer some time ago who said it was also related to the fuselage tank installation. I didn't have the fuselage tank in my airplane so that was never an issue for me anyway. It's interesting what you have brought up about the training manual. It's dating is August 45. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
Dudley,
I don't quite understand how the fuel tank installation relates to the dorsal fairing. Wasn't the fuel tank related to the "ass-heavy" CG on the B-model (or did that also apply to the D)? The airflow off the canopy makes a lot more sense to me. I'm not trying to pick nits here, just curiousity has reared it's ugly head. 8-) Don McIntyre Clarksville, TN |
![]() "Don McIntyre" wrote in message oups.com... Dudley, I don't quite understand how the fuel tank installation relates to the dorsal fairing. Wasn't the fuel tank related to the "ass-heavy" CG on the B-model (or did that also apply to the D)? The airflow off the canopy makes a lot more sense to me. I'm not trying to pick nits here, just curiousity has reared it's ugly head. 8-) I wouldn't disagree with this . Just mentioned it because it was a NA engineer who threw it out there to us at one time. In my opinion it was the canopy change that necessitated the need for the dorsal extension. I remember questioning him at the time as well. Dudley |
Dudley Henriques wrote:
"Don McIntyre" wrote in message oups.com... Dudley, I don't quite understand how the fuel tank installation relates to the dorsal fairing. Wasn't the fuel tank related to the "ass-heavy" CG on the B-model (or did that also apply to the D)? The airflow off the canopy makes a lot more sense to me. I'm not trying to pick nits here, just curiousity has reared it's ugly head. 8-) I wouldn't disagree with this . Just mentioned it because it was a NA engineer who threw it out there to us at one time. In my opinion it was the canopy change that necessitated the need for the dorsal extension. I remember questioning him at the time as well. It sort of makes sense. The "ass-heavy" ![]() stability, the dorsal fairing contributes to stability. The bubble canopy upset the airflow behind it and in front of the fin, the dorsal fairing may have improved this. So the question is whether the dorsal fairing was added for the first reason, the second, or both. The airplane may be too old a design to get a definitive answer, but I wouldn't be surprised if they added the fairing for both reasons. |
Jim Carriere writes: Dudley Henriques wrote: "Don McIntyre" wrote in message oups.com... Dudley, I don't quite understand how the fuel tank installation relates to the dorsal fairing. Wasn't the fuel tank related to the "ass-heavy" CG on the B-model (or did that also apply to the D)? The airflow off the canopy makes a lot more sense to me. I'm not trying to pick nits here, just curiousity has reared it's ugly head. 8-) I wouldn't disagree with this . Just mentioned it because it was a NA engineer who threw it out there to us at one time. In my opinion it was the canopy change that necessitated the need for the dorsal extension. I remember questioning him at the time as well. It sort of makes sense. The "ass-heavy" ![]() stability, the dorsal fairing contributes to stability. The bubble canopy upset the airflow behind it and in front of the fin, the dorsal fairing may have improved this. So the question is whether the dorsal fairing was added for the first reason, the second, or both. The airplane may be too old a design to get a definitive answer, but I wouldn't be surprised if they added the fairing for both reasons. The directional stability of an airplane depends, basically, on where you put it's side area - area ahead of the CG is destabilizing, and area behind it adds to the stability. When they cut down the aft fuselage of the P-51 to put the bubble canopy on hte "D" models, they lost some ditectional stability. (Yaw) The added the dorsal extention to the rudder to try to remedy this, and in the later H-models and the Temco and Cavalier builds put a taller fin on the airplane. The data for this still exists. Buried in the uncatalogued files on the NACA Technical Reports Server are the results of the wind tunnel tests used to determine the H-models fin shape. It's also got the stock D-model data in the report. Note that the P-51 wasn't the only airplane theat needed its directional stability punched up a bit after getting the bubble canopy. A dorsal fin was added to late model P-47Ds, Ms, and Ns, and the Spitfire got a brand new fin & rudder. The fuselage auxilliary tank moved the CG aft, right to, or perhaps a bit beyond, the practical limit for an aft CG. This had a small effect of directional stability, but a huge effect on pitch (longitudinal) stability. The airplane tended to be unstable in pitch, very, very light on the stick at low Gs (Something like 1.5 lbs/G have been reported) and with a felt force reversal somewhere around 4 Gs. This led to NAA and the USAAF devising a bobweight system in the elevator circuit that increased the feel of the airplane in pitch. -- Pete Stickney Without data, all you have are opinions |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 08:34 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
aero-domains for homebuilt experts | secura | Home Built | 0 | June 26th 04 07:11 AM |
JASPO Experts On Civil Aircraft Survivability | sid | Military Aviation | 2 | February 13th 04 07:41 AM |
Aircraft Id needed from newsgp experts! | RGP | Military Aviation | 1 | January 1st 04 07:15 PM |
