I have read that the main difference between the Ovation and the Ovation II is the better prop on the second airplane. Can one
install the new prop on the old model. It's the same airplane and the same engine between both the Ovation and Ovation II, so the only worries are legal ones. Finally, I have read that the Ovation engine is flat-rated by limiting the RPM to 2,500. Can one change the pitch on the prop to get higher performance and how would one make this paperwork work? -Thanks P.S. Nope, I don't actually own a Mooney. I'm just dreaming. |
"Charles Talleyrand" wrote:
Finally, I have read that the Ovation engine is flat-rated by limiting the RPM to 2,500. Can one change the pitch on the prop to get higher performance It's a constant speed prop; it changes its own pitch. Conceivably, one might adjust the prop governor control to allow higher rpm. -- Dan C172RG at BFM |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
