What Bugs You The Most?
Old August 20th 03, 07:02 PM
Ron Natalie
wrote in message ...
As e.drucker said the baggage compartment door blocks the wingwalk and
handhold on a Warrior. There is no inspection plate to service the fuel
level sending unit on the fuel tanks. The tank MUST be removed.
Can you "install" such a plate, or is there something structural in the
way?
Old August 20th 03, 08:22 PM
Ben Jackson
Steve Robertson wrote:
For me, mine has an odd cold starting gremlin. (Lycoming IO-360) It will rarely
start the first time, no matter how long I run the starter or how long I
prime it
with the aux pump. However, it will start on the 2nd blade every time the second
time I run the starter. Weird.
You sure the aux pump is working? Could be you're priming by cranking
the engine pump which gets you the start on the second crank.
Ben Jackson
http://www.ben.com/
Old August 20th 03, 08:53 PM
Steve Robertson
Hmmmm. I guess that's a possiblity. The aux pump makes plenty of noise when it's on.
Wonder if it's really pumping... On the other hand, suppose only the engine pump is
working. Why doesn't it eventually start the first time? Why does it start
*instantly* on the second go?
Best regards,
Steve Robertson
N4732J 1967 Beechcraft A23-24 Musketeer Super III
prime it
Ben Jackson
http://www.ben.com/
Old August 20th 03, 09:41 PM
ShawnD2112
A canopy that doesn't really fit properly and recently developed the
inability to stay properly locked closed.
Shawn
Pitts S-1D G-BKVP
"Charles Talleyrand" wrote in message
Of course everyone thinks their plane is wonderful, but every plane has at
least
one annoying 'feature'. I don't want to hear about cabin width or cruise
speed,
but that minor gremlin you would fix if money was free and time
replaceable.
In my plane, the overflow vent vents too much and full tanks cause it to
drip. Yes, I know how to fix it, and probably will next annual, but
right now
it bugs me.
Wing cleaner Viperdoc Owning 27 July 15th 03 05:03 PM
