Fuel Drip Containment
Old October 27th 03, 04:30 PM
Jon Woellhaf
Hose slipped over vent and part way into can to insure no "drips" miss?
"Jim Weir" wrote in message
That's a thought. You could enhance the probability that the gas would go
into
the can by gluing a funnel into the VENT port on the can, or by simply
drilling
a hole into the top of the can and epoxy-gluing the funnel into permanent
position. I like that idea even more, because the only evaporation THEN
is from
the little tiny funnel hole...and you could go one step further and drill
a cork
stopper with a smaller hole at the top of the funnel neck so the gas would
pass
through, but the evaporation would be much less.
You guyzes is clever. Thanks.
"MichaelR"
-Sporty's oil mat #8667A might work, but I use an open gasoline can on
-floor. There's usually not much wind in a hangar, so the drips will go
right
-in once it is positioned. The small opening in the can reduces the
amount of
-evaporation you would get compared to a mat or just letting it hit the
-floor.
-Afterward, I use the fuel to run my lawnmower.
http://www.rst-engr.com
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Fuel Drip Containment -- My Solution Jim Weir Home Built 4 November 1st 03 05:22 AM
Fuel Drip Containment Sven Home Built 28 October 27th 03 10:28 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
