Pitot heat
Old November 5th 03, 12:17 PM
Paul Mennen
Default Pitot heat
Just saw in this month's AOPA (Fall flights):
"Most pilots slumming around the pattern on a hot summer day
will probably not flip the pitot heat on, but certainly anytime
you're flying in or near moisture - at any air temperature - It's
safest to use pitot heat." - Editor in Chief, Thomas B. Haines.
Well that would cover at least half the time. Probably more if
one forgets to turn it off when the clouds finally slip out
of sight. Does this seem preposterous to anybody else?
Maybe its because my instructor covered up the airspeed indicator
of the J3 cub for an entire flight during my private training
just to make sure I wasn't becoming too dependent on it. Frankly
it didn't seem too hard to fly without it. Since the cub had no
stall warning system, I did use up more of the dirt patch next
to the runway than usual. (My instructor never actually let me
use the runway. He said that was too easy.) In the past 20 years
of flying my C185, I've flown without the airspeed indicator
several times. Twice it failed to work because of stuff in the
pitot tube. Once I just couldn't see it because there was no moon
and I had a total electrical system failure. (Actually I did have
a flashlight in my pocket, but I didn't see a great motivation
for getting it out. I just landed in the dark.) Twice I saw the
airspeed indicator rapidly head to zero because of icing conditions.
(My icing early warning system With constant power, pitch, and
altitude indications from the other instruments it never crossed
my mind to make any control inputs in response. Flipping the
pitot heater on restored the airspeed indicator within seconds.
(Well airspeed is at least a nice convenience.)
So Mr. Haines' suggestion seems somewhat radical to me. (Ok, I guess
I would use it in the cold soup when I'm already dealing with a loss
of vacuum system emergency.) Just think of all that power wasted.
And is really safer? Perhaps having it on so often would mean that it
would more likely be burnt out one of those few times it would be really
nice to have. And maybe it would snuff out that last 10 minutes of
battery capacity that you needed to complete your approach, because it
took you awhile to recognize that the alternator went belly up.
But he certainly has more experience than my meager 3000 hours,
so what do I know?
Reminds me of the instructions in the POH of my Decathlon that says I
should leave the electrical fuel pump on during takeoff because gravity
feed alone is not sufficient to produce takeoff power in the event the
engine driven fuel pump fails. Gosh, what are we - like the
monkeys on the early space missions. Can't we just turn on the
switch when we need it? (I've already replaced that very expensive
electrical pump twice because me or one of my partners forgot to turn
it off after climbout. It is not robust enough to run it continuously.
I've since given up on following the POH exactly.)
~Paul Mennen
Old November 5th 03, 02:55 PM
G.R. Patterson III
It does to me. The pitot heat on my aircraft has been on less than an hour in
over 500 hours.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
Old November 5th 03, 03:08 PM
Ron Natalie
"Paul Mennen" wrote in message .com...
Does what seem preposterous. You'd rather wait until it ices up?
Pitot heat is anti-ice, not de-ice. You'll never turn it on for fear you
will forget to turn it off?
Gosh, and you want to wait until the engine quits on takeoff to determine
you need to turn it on and wait for a restart while heading for the trees?
Takeoff is one of those times you are using full power and wish to retain
full power even in the event of a pump failure. At cruise, you have more
time to detect the failure and switch on the backup.
Old November 5th 03, 05:31 PM
Paul Mennen
Well yes actually. For one I don't think the engine would quit since
you still have considerable fuel flow due to gravity feed. I have no
way to test that, but even if the engine quit, the prop would not stop.
(I've tried to stop the prop before after pulling the mixture. It takes
quite some time and one has to be flying very slowly.) So once turning
the fuel pump switch on, the engine would run almost immediately (at
least it would if I haven't burnt out the electric pump from over use
Another thing I might add, is that failure of the engine driven pump
is very rare. The chance that it would fail during the 20 seconds or so
of vulnerability (where the time it takes you to think of turning on
the switch really matters) seems to fall into the statistically
insignificant
range.
I think the engineer who thought to include the electric fuel
pump was thinking rationally. I think the person who wrote in
the POH that you should turn it on prophylactically was not.
~Paul
Old November 5th 03, 05:37 PM
Ron Natalie
"Paul Mennen" wrote in message news
If it died completely, you might think of that. What if the thing just dropped
to 25% power. Would the boost pump be the first thing you tried?
I fly a low wing, so using the boost on takeoffs is standard procedure. I've
never been tempted to forget to turn it off. The thing in my plane is pretty
noisy (it sits right under the right seat pilots feet).
Old November 5th 03, 07:26 PM
Russell Kent
Must make it a challenge for Margy to work the rudder pedals... vbg
Russell Kent
Old November 5th 03, 07:53 PM
Doug
Well water does not freeze until 0 degrees C at any pressure we pilots
will see. It is true that there is a problem getting an accurate
static temperature at speed and it is also true that you can have
pockets of lower pressure creating lower temperatures around the wing
etc, but I would say that you certainly don't have to worry about
freezing Pitot until 5 degrees C or if you want to be conservative 10
degrees C. It is not like carb ice where you can get freezing temps in
the carb at outside static temps of, well up to 25 degrees C or so. So
I agree, the guy, if he really did write that, is not really on the
ball here, you don't need pitot heat on a hot summer day, no way.
"Paul Mennen" wrote in message y.com...
so what do I know?
~Paul Mennen
Old November 5th 03, 08:31 PM
Newps
will see.
And yet at 5000 feet you need to adjust how you bake because of the
different boiling point of water.
Old November 5th 03, 08:38 PM
Ron Natalie
"Russell Kent" wrote in message ...
Nah, she just sits on the left side.
Old November 5th 03, 08:53 PM
Ron Natalie
"Newps" wrote in message news:86dqb.113533$Fm2.101588@attbi_s04...
will see.
Freezing and boiling are different processes. Freezing is not much
affected by pressure. Boiling on the other hand is DEFINED in terms of
pressure. It's the point where atmospheric pressure equals the vapor pressure.
At 5000' (and altimieter setting 29.92), the boiling point is only 202 degrees
The liquid water never can get above the boiling point, so the temperature
of the food stays cooler and hence it takes LONGER to cook things that
are boiled.
However, the reason baking instructions change is only partially the boiling
point. In baking the food rises due to leavening (yeast, baking powder, etc...)
This process (amount of leavening used, temperatures, etc...) is generally
set for sea level pressures. At higher altitudes, these recipes tend to
over-rise. Adding addional flour or other adjustments to the recipe
compensate for this.
Freezing (of water) is affected by pressure, but to raise the freezing point requires
rather severe decrease in pressure. Between 0 and 5000 feet the frezing point
difference is less than a degree.
Burning out the pitot heat? Mitty Instrument Flight Rules 3 December 30th 04 05:04 AM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 12:47 PM
28 volt pitot heat B2431 Home Built 15 April 17th 04 03:25 PM
pitot heat question K. Ari Krupnikov Instrument Flight Rules 7 December 11th 03 01:51 AM
"I'll spend as much of YOUR money as I want!" - Bu$h's Sunday Presidential Address B2431 Military Aviation 91 September 14th 03 10:05 PM
