Pitot heat
Old November 6th 03, 09:54 AM
Tom S.
And yet at 5000 feet you need to adjust how you bake because of the
different boiling point of water.
Freezing and boiling are different processes. Freezing is not much
affected by pressure. Boiling on the other hand is DEFINED in terms of
pressure. It's the point where atmospheric pressure equals the vapor
pressure.
At 5000' (and altimieter setting 29.92), the boiling point is only 202
degrees
The liquid water never can get above the boiling point, so the temperature
of the food stays cooler and hence it takes LONGER to cook things that
are boiled.
However, the reason baking instructions change is only partially the
boiling
point. In baking the food rises due to leavening (yeast, baking powder,
etc...)
This process (amount of leavening used, temperatures, etc...) is generally
set for sea level pressures. At higher altitudes, these recipes tend to
over-rise. Adding addional flour or other adjustments to the recipe
compensate for this.
Freezing (of water) is affected by pressure, but to raise the freezing
point requires
rather severe decrease in pressure. Between 0 and 5000 feet the frezing
point
difference is less than a degree.
Hey!! Take it to alt.baking.recipes you guys!! :~)
Tom -- I lost the recipe for ice cubes.
Burning out the pitot heat? Mitty Instrument Flight Rules 3 December 30th 04 05:04 AM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 12:47 PM
28 volt pitot heat B2431 Home Built 15 April 17th 04 03:25 PM
pitot heat question K. Ari Krupnikov Instrument Flight Rules 7 December 11th 03 01:51 AM
"I'll spend as much of YOUR money as I want!" - Bu$h's Sunday Presidential Address B2431 Military Aviation 91 September 14th 03 10:05 PM
