Aluminum shrinks and expands more than steel. At some temperature around
10 degrees the case will have shrunk onto the crank and cam to the point where you have zero bearing clearance! Rip Viperdoc wrote: Is it worth lugging long extension cords to plug in the Tanis heaters for my Baron if it's going to sit outside at 12 degrees for two to three hours after a flight? I have cowl plugs which may help a little, but is it really a problem? The oil will be well circulated, and the battery is in good shape to crank the engines. Also, the POH says to keep the cowl flaps open during taxi and take off, but when it's so cold outside does this still make sense? As long as the CHTs remain within a reasonable range what difference should it make? Thanks from Wisconsin, where its 2 degrees and clear. |
Turbine air start -- too cold? | Juan Jimenez | Home Built | 97 | March 14th 05 06:51 PM |
Turbine air start -- too cold? | Juan Jimenez | General Aviation | 54 | February 2nd 05 04:14 AM |
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs | Larry Dighera | Military Aviation | 7 | April 2nd 04 07:05 PM |
Soviet Spy Planes over the West during the Cold War | Rusty B | Military Aviation | 6 | February 19th 04 04:53 PM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
