Cold Starts
Old February 15th 04, 10:13 PM
Dennis O'Connor
I started my engines this morning at -4 F... No preheat never do No
problems; though it did take 6 blades each, before they fired - mucho cold
senor... Use 15W50... I get oil pressure indication in less than ten
seconds... That's the way this airplane has been treated ever since
semisynthetic, multiviscosity, oils came out.... Engines go to TBO
routinely...
denny
"Dale" wrote in message
"Viperdoc" wrote:
Is it worth lugging long extension cords to plug in the Tanis heaters
for my
Baron if it's going to sit outside at 12 degrees for two to three hours
after a flight?
What is an engine worth? g IF you have a cowl blanket and IF the
engine oil will stay warm for that length of time then it shouldn't be a
problem. I would plug it in if it was my airplane.
Also, the POH says to keep the cowl flaps open during taxi and take off,
but
when it's so cold outside does this still make sense? As long as the
CHTs
remain within a reasonable range what difference should it make?
CHTs might be okay but other areas of the engine compartment may be
heating up. I used to fly a B-17 and B-24, we always had the cowlflaps
open on the ground because if they were closed it was possible to heat
damage the sparkplug wires. Big difference in engines I know. If the
POH says leave them open I would. If you've preheated properly the
engine will come up to temp quickly and you'll need them open. Also,
with a change in procedure it would be easy to goof and leave them
closed during takeoff and climb which could really cook things.
Dale L. Falk
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 06:51 PM
Turbine air start -- too cold? Juan Jimenez General Aviation 54 February 2nd 05 04:14 AM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
Soviet Spy Planes over the West during the Cold War Rusty B Military Aviation 6 February 19th 04 04:53 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
