Cold Starts
Old February 20th 04, 03:11 PM
Dennis O'Connor
John, that has been the point I have been beating on... A quick preheat does
nothing, except convince the pilot he is being good to the engine...
A thorough preheat of a number of hours, with adequate insulation and
keeping the wind off the prop blades, does bring the engine core temperature
up, and certainly does no harm...
Leaving heat on the engine all the time may set you up for condensation
rusting - depends on the details...
My experience has been that with semisynthetic, multiviscosity oils
preheating is not necessary - until you reach arctic conditions..
denny
"John Galban" wrote in The reason for the Alaskan
habit is that when temps go low enough, a
chunk of frozen oil can develop in the crankcase. Even after
preheating the engine to what seems to be a suitable temp, you can
have a frozen chunk of oil surrounded by slightly warmer liquid oil.
(PA28-180)
Old February 20th 04, 03:25 PM
Tom Sixkiller
"Dennis O'Connor" wrote in message
does
temperature
Yes...unless you use both a cylinder AND an oil sump heater.
http://www.reiffpreheat.com/FAQ.htm#QA3
Old February 23rd 04, 06:38 PM
Ray Andraka
Even then, without proper insulation you can still get corrosion. I no
longer leave mine plugged in 24/7 (I have Reiff cylinder and oil pad
heaters), because before my recent overhaul my mechanic noted that the front
cams were badly spalled and had sigificant corrosion where the rear ones
looked nearly new. The most likely explanation was the uninsulated prop
acting as a heat sink on the front end of the engine providing for a heavier
condensation density near the front of the engine. Reiff's article does say
to use a cover, but they fail to mention also insulating the prop.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 06:51 PM
Turbine air start -- too cold? Juan Jimenez General Aviation 54 February 2nd 05 04:14 AM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
Soviet Spy Planes over the West during the Cold War Rusty B Military Aviation 6 February 19th 04 04:53 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
