Ron Wanttaja wrote:
: That's the other factor of course. I've only seen tailhook installation on : taildraggers, but I doubt that, on trigear airplanes, they merely unscrew : the tiedown ring and screw in the hook release mechanism. There's probably : reinforcement that's added as well, which would make moot any comparison to : pulling the plane by the stock tiedown ring. FWIW, the banner tower based at my field uses a Cessna Hawk XP. The banner tow point is the tail tiedown. I asked if there are any reinforcements added, and he said "No.". -- Aaron Coolidge (N9376J) |
Towhook is available as standard equipment on all C182's. No reinforcements
added. THE 182 has been towing for more than 40 years now. The hook bolts in place of the tiedown ring. It will tow a considerable amount of weight, to understate things a bit. It's bad form to break the rope on tow, but it can happen. In article , wrote: On Sat, 21 Feb 2004 14:06:51 GMT, (d b) wrote: Using this range, 850 to 2000 pounds on the tail of a towplane is not out of reason. Another place in the installation design of tail hooks calls for loads to stay within 30 degrees of backwards, as I recall. I would try to keep the load as straight aft as possible. That's the other factor of course. I've only seen tailhook installation on taildraggers, but I doubt that, on trigear airplanes, they merely unscrew the tiedown ring and screw in the hook release mechanism. There's probably reinforcement that's added as well, which would make moot any comparison to pulling the plane by the stock tiedown ring. On taildraggers, the line releases are generally attached to the tailwheel spring...which, of course, already has a heavy-duty attachment. Homebuilders and antique owners use the same devices to secure planes during handpropping. See: http://www.bowersflybaby.com/tech/tailhook.html Ron Wanttaja |
WWII warplanes vs combat sim realism | [email protected] | Military Aviation | 37 | November 27th 03 05:24 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
A Good Story | Badwater Bill | Home Built | 15 | September 3rd 03 03:00 PM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
