There should be an acceptable range that will be listed in your
maintenance manual. I'm sure that being in the green at full throttle will not be harmful to the gauge. Even vacuum a bit lower than the green should be sufficient to spin the gyros. Check the lines for a pinhole leak, which could also be introducing dirt into the instruments. I won't give you the ol' "I told you so" about having a recent instrument rebuilt just yet! In the last couple of months we have replaced both vacuum instruments (DG and AI) as well as all vacuum hoses. Immediately after this was done, I noticed our suction was lower than before. It would top out in the 4.8 region -- at the very low end of the acceptable scale. At the same time we also noticed that our newly overhauled DG was precessing excessively. It would precess 10 degrees every 15 minutes or so. Sometimes less. Before we pulled and returned the DG, I wanted to make sure that the lower suction wasn't part of the problem, so today I had my A&P adjust the vacuum regulator. It's now reading 5 at 2000 rpm, and almost 5.2 (the high end of acceptable) at full throttle in a ground run. We left it at the high setting to see where it settles out after a flight or two. Question: Will this increase in vacuum help the DG's precession problem, or is the DG toast? |
The Meredith Effect | Corky Scott | Home Built | 19 | September 4th 04 04:01 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Effect on aeroplane of sudden depressurisation | Guy Lux | General Aviation | 9 | February 23rd 04 06:30 PM |
Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 05:11 AM |
Great Lakes lake effect snow | Paul Tomblin | Instrument Flight Rules | 30 | October 21st 03 05:15 PM |
