Several years ago I bought a '61 straight back for my wife and was shy about
the 0-300. Since then I've grown to love it. It does run smooth and all her instructors rave about it. For some reason the plane is unusually quick also. Climb is average. 1. What kind of fuel burn do you consistently get with an O-300? Is the generally reported 105 KIAS @ 8 GPH true? At 105 KIAS I actually think it's a little better, maybe 7GPH. 2. Does the autogas STC help reduce the problem with valve sticking? If you have the STC, do you generally burn a mix? Got the STC and been burning pure regular. It runs noticably better (and considerably cheaper) but we are agressive about applying carb heat even though I have never felt a trace of ice. The guy who sold it to me said it never saw auto gas. Used a lot of oil so I took the top end apart. Only one valve was slightly close to snug but 3 of 6 cylinders had one or more frozen rings from carbon and goo. The cylinders mic-ed up within spec. (An A&P told me the older cylinders were great but the new ones are too soft. How do I know?) Put new rings on and now the engine is running sweet. This was the first thing done to it in 1800 hours. 3.In general, has your experience led you to expect to have to do a top overhaul about halfway through the TBO period? What are the ballpark costs of such an operation. The ring job, 1 wrist pin, 2 valve guides and a gasket set cost me a tick over $400. 4. In your opinion, would it be worth it to pay the premium to buy an new 172 equipped with the O-320E2D? My biggest bitch is that those Continentals seem impossible to stop from leaking oil. The Lyc. in my other plane is always dry. 5. Besides the valve guide and cylinder problems (often attributed to running on 100 LL), are there any other major problems that would make this an undesireable aircraft? Thanks for the help, Cap Jim |
![]() "JFLEISC" wrote in message ... Several years ago I bought a '61 straight back for my wife and was shy about the 0-300. Since then I've grown to love it. It does run smooth and all her instructors rave about it. For some reason the plane is unusually quick also. Climb is average. 1. What kind of fuel burn do you consistently get with an O-300? Is the generally reported 105 KIAS @ 8 GPH true? At 105 KIAS I actually think it's a little better, maybe 7GPH. 2. Does the autogas STC help reduce the problem with valve sticking? If you have the STC, do you generally burn a mix? Got the STC and been burning pure regular. It runs noticably better (and considerably cheaper) but we are agressive about applying carb heat even though I have never felt a trace of ice. The guy who sold it to me said it never saw auto gas. Used a lot of oil so I took the top end apart. Only one valve was slightly close to snug but 3 of 6 cylinders had one or more frozen rings from carbon and goo. The cylinders mic-ed up within spec. (An A&P told me the older cylinders were great but the new ones are too soft. How do I know?) Put new rings on and now the engine is running sweet. This was the first thing done to it in 1800 hours. 3.In general, has your experience led you to expect to have to do a top overhaul about halfway through the TBO period? What are the ballpark costs of such an operation. The ring job, 1 wrist pin, 2 valve guides and a gasket set cost me a tick over $400. 4. In your opinion, would it be worth it to pay the premium to buy an new 172 equipped with the O-320E2D? My biggest bitch is that those Continentals seem impossible to stop from leaking oil. The Lyc. in my other plane is always dry. Some leak, some don't. Most do but not much. I am flying a friend's 172 at the time which is just absolutely a joyful experience. It's a '56 172 with the straight tail and that great Johnson bar between the seats. It gets off and climbs with a vengeance and the O-300 runs wonderfully. Great sound too and smoooooth. A 4-banger Lycoming never ran this smooth. My first experience with an O-300 was in a ragwing 170, and I was instantly in love. I'm restoring another 172 which I have flown too, O-300 engine also, but this one is a '66 and needs cylinders. So what? You can buy cylinder kits today for half what you could buy them for ten years ago, thanks to competition among TCM, ECI, and Superior. The cylinders don't always last to TBO but the bottom end is very durable and solid. I know of a trusty O-300 in an old 172 nearby with over 2300 hours on the bottom end and still running strong. He's busted TBO by over 500 hours. To extend the life of the cylinders I would lean carefully and monitor cht and egt religiously. Change oil every 25 hours. And make power changes smoothly, gradually. I'd also watch the baffling, avoid 100LL except as a mix of 10% avgas and 90% mogas because the low-compression engine is not designed for high-leaded, hi-octane gas like 100LL. Fly regularly and no cold starts below freezing temperatures. A good oil filter is a must. I'd also use an additive to leech out lead fouling and carbon deposits and keep the plugs cleaned and gapped. Watch your mag timing. I firmly believe that MMO and Alcor TCP are helpful (one or the other), especially in the O-300 using avgas, to keep valves from sticking. Read more about these great engines in the 172 forum in Yahoogroups. The current discussion is about MMO and its obvious benefits. I don't need graphs, charts, engineering reports and so-called hard data and statistical studies to convince me MMO is desirable. And, btw, I put a capful of MMO in my Harley's tank every fillup back in the 70's as advised by H-D Motor Company. And finally, if you haven't flown Continental's six bangers, including the O-300 and its grandbaby, the IO-360, you just THINK you've flown an aircraft. |
about MMO and its obvious benefits. Can you suggest how much MMO should go into the engine and how much should go into the fuel? www.Rosspilot.com |
![]() "Rosspilot" wrote in message ... The current discussion is about MMO and its obvious benefits. Can you suggest how much MMO should go into the engine and how much should go into the fuel? www.Rosspilot.com Rosspilot, I use it sparingly, about 2 oz. per 24 gallon fillup, and in the fuel tanks only. It wouldn't hurt to put an ounce or two in your oil, but I never saw the need to. |
fuel tanks only. Thanks . . . I put some in my fuel tanks when I started using auto gas, and started to see gray streaks along the right side of the engine cowling--apparently coming from the exhaust. It wiped right off, but I didn't know what it was. When I stopped using MMO, the streaking also stopped. Maybe I used too much . . . any ideas what the gray streaks were? www.Rosspilot.com |
Is hyraulic drive posible? | PAW | Home Built | 38 | July 9th 04 08:03 AM |
Bush AWOL Story - New theory comes to light | Laura Bush murdered her boy friend | Military Aviation | 187 | March 30th 04 07:52 AM |
Stryker/C-130 Pics | robert arndt | Military Aviation | 186 | October 8th 03 09:18 AM |
Jabiru V Rotax reliability? | Joe | Home Built | 11 | September 5th 03 11:09 AM |
Space Junk & GPS Reliability | Doug Carter | Instrument Flight Rules | 9 | July 11th 03 01:38 PM |
