![]() "Jay Honeck" wrote in message news:iI76c.32458$_w.542610@attbi_s53... Is it worth the bother? We're coming up on our annual inspection in May, and there are at least four antennas on our bird that do nothing. I'll bet there's a few feet of cable going to each one, too. Does removing an antenna net you any extra speed, or is it mainly a weight reduction thing? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Jay, You have no choice. You are REQUIRED to remove inoperative equipment. Part 91.405 (c). Best, Karl. BTW, the reg says the equipment must be repaired, replaced, removed or inspected at the next required inspection. What they mean by "inspected" is if a required inspection is due. Not just the mechanic peering at a piece of inop equipment and letting it go for another year! This rule is regularily ignored by the GA community. But it would never fly at a reputable repair facility. Once the antennas are removed you will have to revise the equipment list and weight and balance. "Curator" N185KG, fire breathing Skywagon! |
Oh, Christ. Here we go again...
Jim "kage" shared these priceless pearls of wisdom: - -You have no choice. You are REQUIRED to remove inoperative equipment. Part -91.405 (c). - -Best, -Karl. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Wed, 17 Mar 2004 19:46:28 -0800, Jim Weir wrote:
Oh, Christ. Here we go again... Jim That's EXACTLY (word for word) what my response was going to be! |
They are working spares so they can Stay :-)
Michelle kage wrote: "Jay Honeck" wrote in message news:iI76c.32458$_w.542610@attbi_s53... Is it worth the bother? We're coming up on our annual inspection in May, and there are at least four antennas on our bird that do nothing. I'll bet there's a few feet of cable going to each one, too. Does removing an antenna net you any extra speed, or is it mainly a weight reduction thing? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Jay, You have no choice. You are REQUIRED to remove inoperative equipment. Part 91.405 (c). Best, Karl. BTW, the reg says the equipment must be repaired, replaced, removed or inspected at the next required inspection. What they mean by "inspected" is if a required inspection is due. Not just the mechanic peering at a piece of inop equipment and letting it go for another year! This rule is regularily ignored by the GA community. But it would never fly at a reputable repair facility. Once the antennas are removed you will have to revise the equipment list and weight and balance. "Curator" N185KG, fire breathing Skywagon! -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
![]() kage wrote: You have no choice. You are REQUIRED to remove inoperative equipment. All of these antennae work just fine, so they don't have to be removed. There's no reg that says they have to be connected to anything. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
"kage" wrote in message ...
"Jay Honeck" wrote in message Jay, You have no choice. You are REQUIRED to remove inoperative equipment. Part 91.405 (c). Best, Karl. BTW, the reg says the equipment must be repaired, replaced, removed or inspected at the next required inspection. What they mean by "inspected" is if a required inspection is due. Not just the mechanic peering at a piece of inop equipment and letting it go for another year! This rule is regularily ignored by the GA community. But it would never fly at a reputable repair facility. Once the antennas are removed you will have to revise the equipment list and weight and balance. WRONG!!!!! 91.405(c) each owner operator blah blah blah (c)shall have any inoperative instrument or item of equipment permitted to be blah blah blah. Inspected means. You have that piece of equipment inspected to be sure it is still deactivated. For an example: Say I have a Piper Arrow with inop air conditioning. I can deactivate and placard that system. Never have it fixed. As long as. At the next required inspection.(IE 100 hr or annual), I inspect it to make sure it is still deactivated and placarded AND Make a logbook entry of such. Good to go till next inspection.... Joe A&P/IA |
Dream on mamma,
Say what you want. Like I said, it is generally ignored by shade tree mechanics working on Piper Arrows. But if you bring your Gulfstream into a legitimate shop your inoperative equipment WILL be repaired, replaced, removed or required inspections performed and the equipment returned to service. inspected"joe mamma" wrote in message om... "kage" wrote in message ... "Jay Honeck" wrote in message Jay, You have no choice. You are REQUIRED to remove inoperative equipment. Part 91.405 (c). Best, Karl. BTW, the reg says the equipment must be repaired, replaced, removed or inspected at the next required inspection. What they mean by "inspected" is if a required inspection is due. Not just the mechanic peering at a piece of inop equipment and letting it go for another year! This rule is regularily ignored by the GA community. But it would never fly at a reputable repair facility. Once the antennas are removed you will have to revise the equipment list and weight and balance. WRONG!!!!! 91.405(c) each owner operator blah blah blah (c)shall have any inoperative instrument or item of equipment permitted to be blah blah blah. Inspected means. You have that piece of equipment inspected to be sure it is still deactivated. For an example: Say I have a Piper Arrow with inop air conditioning. I can deactivate and placard that system. Never have it fixed. As long as. At the next required inspection.(IE 100 hr or annual), I inspect it to make sure it is still deactivated and placarded AND Make a logbook entry of such. Good to go till next inspection.... Joe A&P/IA |
Kage,
I do agree with you about it being ignored. Alot of pilots/owners are not aware of this loophole. In fact, AOPA I believe,or maybe it was Aircraft technician, Did an article on this very same subject. What gets most people is that the equipment was deactivated and every thing is fine but they fail to make a logbook entry noting the deactivated equipment was in fact inspected. As for your comments infering that because an A&P works on A Piper Arrow, he is a shade tree mechanic....well it's just an assholic comment.I have seen outstanding single engine mechanics. By the way, I have been working on GII, GIII, GIV for about 20 yrs. Have done engine changes, 72 month inspections..just about everything....And Yes, I have left SAV. with properly deactivated equip.... Joe "kage" wrote in message ... Dream on mamma, Say what you want. Like I said, it is generally ignored by shade tree mechanics working on Piper Arrows. But if you bring your Gulfstream into a legitimate shop your inoperative equipment WILL be repaired, replaced, removed or required inspections performed and the equipment returned to service. inspected"joe mamma" wrote in message om... "kage" wrote in message ... "Jay Honeck" wrote in message Jay, You have no choice. You are REQUIRED to remove inoperative equipment. Part 91.405 (c). Best, Karl. BTW, the reg says the equipment must be repaired, replaced, removed or inspected at the next required inspection. What they mean by "inspected" is if a required inspection is due. Not just the mechanic peering at a piece of inop equipment and letting it go for another year! This rule is regularily ignored by the GA community. But it would never fly at a reputable repair facility. Once the antennas are removed you will have to revise the equipment list and weight and balance. WRONG!!!!! 91.405(c) each owner operator blah blah blah (c)shall have any inoperative instrument or item of equipment permitted to be blah blah blah. Inspected means. You have that piece of equipment inspected to be sure it is still deactivated. For an example: Say I have a Piper Arrow with inop air conditioning. I can deactivate and placard that system. Never have it fixed. As long as. At the next required inspection.(IE 100 hr or annual), I inspect it to make sure it is still deactivated and placarded AND Make a logbook entry of such. Good to go till next inspection.... Joe A&P/IA |
![]() "joe mamma" wrote in message om... Kage, As for your comments infering that because an A&P works on A Piper Arrow, he is a shade tree mechanic....well it's just an assholic comment.I have seen outstanding single engine mechanics. Of course, Joe, I said that tongue in cheek, knowing it would get a rise. This IS Usenet! One must keep the standards up. I guess the point is that one can find some scum bag mechanic to sign off on anything. Just like you can find some "assholic" pilot to fly that same airplane away. My own mechanic was charging $35/hr. five years ago. He was always complaining about the way he was treated by his customers.They always wanted something for nothing, for him to sign off on questionable items, borrowing his tools, borrowing his hangar, questioning his knowledge about airworthy parts, showing him how to "correctly" do his job.....etc, etc. I seriously urged him to raise his rates, which he did, in several increases over the years. He is now at $95/hr. He is still busy. But, ALL of the freeloaders have gone away. Plus, he has time for his own projects that make him far more money than doing annuals. I am now suggesting to him that $105 sounds somehow psychologically lower than $95. I want him to stay in the business and be comfortable. His knowledge of my airplane is exceptional and his basement is full of new parts from his old, closed, large shop, from which he too, escaped. Congratulations on escaping SAV. Karl |
Removing water repelent from fiberglass lay-up? | Roger | Home Built | 2 | December 2nd 04 11:15 PM |
Do ADF antennas need replacing if changing the receiver? | [email protected] | Owning | 5 | December 11th 03 10:13 PM |
Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 02:51 AM |
Hidden Antennas | Dick Goff | Home Built | 2 | August 20th 03 05:23 PM |
F-14 squadrons removing refueling cover plate? | dave999 | Military Aviation | 7 | August 6th 03 09:45 AM |
