Compression Tests
Old March 22nd 04, 03:51 PM
Doug
Default Compression Tests
Does anyone do an "automotive" type compression test on their aircraft
engine? I think this kind of "dynamic" test might show problems (such
as valves not opening all the way), that a leakdown test would not
(and vice-versa). Anyway my annual is coming up and I want to do it. I
imagine something that screws in and has a long hose to the guage, so
no one has to stand behind the propellor.
Old March 22nd 04, 04:16 PM
Jim Weir
Although I'll do either one the owner wants, I prefer the automotive style
tester. I can hear wheezes and such using this method that the other test just
will not show. Whistle through the carb, you've got an intake valve leak.
Singing out the exhaust, exhaust valve. Blowing out the crank vent and it is
blowby the rings. Lots of good information.
AND you don't have to get in the arc of the propeller and hold it steady against
80 pounds of pressure...you KNOW the propeller is going to spin.
P.S. It is not necessary to put the same question in all the rec.aviation.*
newsgroups. Most of us read them all and it is just a waste of bandwidth. This
one probably belongs in ra.owning.
(Doug)
-Does anyone do an "automotive" type compression test on their aircraft
-engine? I think this kind of "dynamic" test might show problems (such
-as valves not opening all the way), that a leakdown test would not
-(and vice-versa). Anyway my annual is coming up and I want to do it. I
-imagine something that screws in and has a long hose to the guage, so
-no one has to stand behind the propellor.
http://www.rst-engr.com
Old March 22nd 04, 11:30 PM
JDupre5762
engine?
This used to be more common than the differential compression test. I have
seen a set up for a 9 cylinder radial engine that had 9 adapters and gauges so
that you can do all 9 cylinders at one time. I believe the gauges would hold
the highest reading until reset.
The old version of the AC 43.13 Acceptable Methods, Practices and Techniques,
used to mention the direct compression test as acceptable. I believe that the
current AC 43.13-1B no longer mentions it. Which begs the question is the
direct compression test no longer acceptable?
John Dupre'
Old March 26th 04, 06:20 AM
Pat Barry
You can conduct whatever you like - however your IA will require that a
leak down test be performed since it is prescribed under Part 43.
Old March 26th 04, 11:08 PM
prove it.
TC
Old March 27th 04, 04:03 AM
On Fri, 26 Mar 2004 18:35:32 -0500, "Gene Kearns"
Here is the train of thought.....
Example, Lycoming engine (Continental is similar):
FAR 43.13(a)
Lycoming SSP-399 Page 1
Lycoming SI 1191
I like it, but...
43.13(a) is a catch-all reg, kinda like conduct unbecoming for a
pilot. BTW, does it mention "inspection"?
Lycoming may consider all it's publications mandatory/regulatory, but
I'm afraid in reality, the FAA does not, unless you are operating Pt
135 (ref 135.421 if memory serves).
TC
Old March 27th 04, 05:29 AM
Jim Weir
Pat Barry
-You can conduct whatever you like - however your IA will require that a
-leak down test be performed since it is prescribed under Part 43.
That happens to be bull****.
Old March 27th 04, 03:48 PM
Dennis O'Connor
Uh, Gene, I will be less blunt than Jim and TC, and a bit more
informative... You are not reading carefully enough..
An IA is signing off a condition inspection, which is is not maintenance and
therefore 43.13(a) does not apply.
The regulatory language that specifically applies to the annual/100 hour
condition inspection is 43.15(c)(2)i,ii,iii,iv and Appendix D. No where
in those paragraphs will you see a leakdown test required.
denny
"Gene Kearns" wrote in message
On Fri, 26 Mar 2004 18:08:26 -0500, wrote:
Military looks to next round of tests for Osprey Otis Willie Military Aviation 0 September 18th 04 11:01 PM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
Compression Tests Doug Aerobatics 4 March 27th 04 05:29 AM
Compression Tests Doug General Aviation 5 March 27th 04 05:29 AM
Not Particularly Impressed with Tuskegee Airmen Propaganda. The Enlightenment Military Aviation 25 July 11th 03 09:01 PM
