Fabric or metal wings?
Old March 29th 04, 03:58 PM
Malcolm Teas
Default Fabric or metal wings?
Ok, so my wife and I are interesting in buying our first airplane.
Like lots of first-time owners, we're looking for low cost of
ownership. Our basic needs a
- radios and transponder (we're under the DC ADIZ)
- carry us two, our 35 lb dog, or an occasional passenger.
- ability to make 2-3 hour trips
- can be stored at a tie down as hangar costs are too high.
I want to go for an IFR one day, so an IFR certification is a very
good thing too if possible.
We're debating on fabric covered wings or metal. I've been told that
fabric wings shouldn't be outside. Then I've been told that with the
new synthetic fabrics and paints, that a tie down is perfectly fine.
If a fabic wing would work outside, I'd prefer that as I also
understand that the cost of ownership is lower.
Anyone have knowledge or experience here that would help?
-Malcolm Teas
JYO
Old March 29th 04, 04:13 PM
Mike Rapoport
"Malcolm Teas" wrote in message
om...
-Malcolm Teas
JYO
Why would the cost of owning a fabric covered airplane be lower? You have
all the costs of a metal wing aircraft PLUS the cost of maintaining the
fabric.
Mike
MU-2
Old March 29th 04, 04:41 PM
G.R. Patterson III
New fabrics such as Ceconite last pretty much forever if properly applied and
painted. Tiedown is fine. The old natural fiber fabrics will last as little as
two years if left outside. Polyfiber and Ceconite are two different methods of
covering an aircraft with a synthetic fabric. Either method works well and the
fabric used is the same. Those are the two most common modern covering methods.
While it might be cheaper to buy a particular fabric aircraft, I doubt that the
maintenance costs of one would be less than that of an identical metal aircraft.
A Cessna 170A will cost you the same as a 170B in care and feeding.
George Patterson
Treason is ne'er successful, Sir; what then be the reason? Why, if treason
be successful, Sir, then none dare call it treason.
Old March 29th 04, 04:48 PM
Malcolm Teas wrote:
: Ok, so my wife and I are interesting in buying our first airplane.
: Like lots of first-time owners, we're looking for low cost of
: ownership. Our basic needs a
: - radios and transponder (we're under the DC ADIZ)
: - carry us two, our 35 lb dog, or an occasional passenger.
: - ability to make 2-3 hour trips
: - can be stored at a tie down as hangar costs are too high.
: I want to go for an IFR one day, so an IFR certification is a very
: good thing too if possible.
: We're debating on fabric covered wings or metal. I've been told that
: fabric wings shouldn't be outside. Then I've been told that with the
: new synthetic fabrics and paints, that a tie down is perfectly fine.
: If a fabic wing would work outside, I'd prefer that as I also
: understand that the cost of ownership is lower.
: Anyone have knowledge or experience here that would help?
: -Malcolm Teas
: JYO
Can't say about the fabric/metal wings except that for the most part, the
fabric planes are older and thus often cheaper to buy initially. If you know how to
repair fabric or have connections with an A&P that does, it might be fairly
inexpensive to maintain. Somethink like a Tri-Pacer would fit that bill.
That said, I'd recommend a Cherokee 140. Not sexy, not fast, but with a
moderate loading like that (2 x 180 + 100), you're still 100 lbs under gross with 5-6
hours of fuel on board. They're IFR-able too.
Just a thought.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old March 30th 04, 01:38 AM
My first airplane was a Cherokee 140, and I'll agree it would seem to be
just about the ideal airplane to match your needs/wants. Economical to buy
and operate, great flying qualities, an excellent instrument trainer,
bulletproof Lycoming 0-320 engine, and a capable (if not terribly fast)
touring airplane. Ours lived outside in he damp Pacific Northwest for many
years with no corrosion problems. (The original paint did get pretty
scruffy, though.)
-Elliott Drucker
Old March 30th 04, 08:44 PM
Malcolm Teas wrote:
: wrote in message news:
: That said, I'd recommend a Cherokee 140. Not sexy, not fast, but with a
: moderate loading like that (2 x 180 + 100), you're still 100 lbs under gross with 5-6
: hours of fuel on board. They're IFR-able too.
: The Cherokee 140 school of thought seems strong! We're looking at a
: couple of them and considering it. Any particular things to watch out
: for on this plane?
: -Malcolm
Our thought on the Cherokee was that by the book, it's just like a 172, but
roughly $10K less. Realistically, they fly a bit different (172 glide well,
Cherokees' chubby wings make the glide like the Warner Bros. anvil), but not enough to
get uptight about.
As far as gotchas with it, the biggest would be whether or not it sat for a
long time. Lycomings in particular tend to rust their camshafts if not flown enough.
Another potentially expensive oops is blown exhaust gaskets on the engine. If not
caught early, the hot gasses can blow out the sealing surface on the cylinders and
require cylinder replacement in addition to gasket replacement.
WRT airframe stuff, check the wings under the flaps by the fuselog for
corrosion. Also, the cabin floors and inside firewall because of notoriously leaky
doors and windshields. Pre-1969 models have a shotgun-blast panel layout (no standard
T-layout) and fuses, rather than breakers. If you're going to do instrument training,
it's nice to have the standard T-layout, but realistically it's what you get used to.
Check the stabilator for slightly lose bearings, and gear struts for leaks.
Basically, much of the general pre-purchase stuff. They're pretty light on
bad AD's and such.
-Cory
Old March 31st 04, 06:29 PM
TTA Cherokee Driver wrote:
: what? you mean that if a Cherokee 140 loses power it hangs in the air
: long enough for the occupants to hold up a little sign that says "uh-oh"
: and then plunges to the ground? That's not a maneuver I learned
Yeah... you got it... It was a noticable difference switching from a 172
to a PA-28 in that regard. By the book, they both say about a 9:1 glide ratio, but my
personal experience has been different. I put droopy wingtips and VG's on the
Cherokee which help some, though.
-Cory
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
P-51 wings: silver paint or natural metal ? Vicente Vazquez Military Aviation 7 July 13th 04 01:37 AM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Fabric repair D.A.L Home Built 0 April 27th 04 07:17 PM
Fabric Work Doug Home Built 9 January 26th 04 03:31 AM
