"O. Sami Saydjari" wrote in message ...
Well, it happended. I have owned the plane (Piper Turbo Arrow III) for 3 months and the engine failed during climb out on Tuesday. Altitude was 4400 feet. Luckily, the engine did not entirely quit and I made it to an airport within 10 miles. TBO was 1000 hours away. Dissapointing! When we cut the oil filter, it was full of fairly large aluminum and steel bits of metal. Arg! What is wrong with this engine? The symptoms surely don't relate to P leads or magneto wires. Why not run a compression check on it? Take off the valve cover on any suspicious cylinders. What's in there? Take off the cylinder, if you figure out that it's only one. See what's going on. What's the cam look like? With the cylinder off, you can look inside the case for clues. There are a lot of failures where you could do a repair and be back in business--unless something got loose and whanged around inside. The oil filter probably kept stuff out of the bearings. It wouldn't be much of an investment in time to investigate. Plus, we all want to know what busted!! Heck, you can even do this yourself. It's a hard running engine. Bill H |
![]() Why not run a compression check on it? Take off the valve cover on any suspicious cylinders. What's in there? Well, I was traveling on business when the failure happened, I could only spend the next morning with it before I had to be flown home (commercially, arg!). Also the shop where I was had several fires happening simultaneously and were short handed, so they were unwilling to investigate beyond pull the spark plugs and cutting the oil filter. Take off the cylinder, if you figure out that it's only one. See what's going on. What's the cam look like? Well, I am sending my A&P out there on Monday and I hope to learn these details from him. I will report back. My skill level is not at the point I could have easily done these things myself. Sorry to tease you with scant description and not be able to provide the details. With the cylinder off, you can look inside the case for clues. There are a lot of failures where you could do a repair and be back in business--unless something got loose and whanged around inside. The oil filter probably kept stuff out of the bearings. That would be nice. My A&P suspects that the bearings are likely fouled, but we will find out. It wouldn't be much of an investment in time to investigate. Plus, we all want to know what busted!! Heck, you can even do this yourself. Would it were so. Perhaps in a few years ![]() It's a hard running engine. Bill H |
If it were me, and knowing that the oil pressure dropped off to near zero, plus all the metal, I would not
opt for anything less than a complete overhaul. Even if the obvious damage is isolated to one cylinder, you don't know what damage the low oil pressure and all that metal did elsewhere. It would really suck to spend a bunch of cash on a fix only to have it happen again. Besides, right now, the cost of an overhaul is relatively low compared to the prices over the last few years. If there were no metal, and the oil pressure hadn't dropped, then maybe, but not under those circumstances. Bill Hale wrote: There are a lot of failures where you could do a repair and be back in business--unless something got loose and whanged around inside. The oil filter probably kept stuff out of the bearings. It wouldn't be much of an investment in time to investigate. Plus, we all want to know what busted!! Heck, you can even do this yourself. It's a hard running engine. Bill H -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
![]() Sure, it kept the stuff out of the bearings. But the oil pump is upstream of the filter, and all that metal garbage went through it and chewed it up. "Fixing up" the engine is spending money on an engine that will fail again very shortly, if it generates any oil pressure at all. Nothing less than complete teardown is necessary here. Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. |
"O. Sami Saydjari" wrote: Sure, it kept the stuff out of the bearings. But the oil pump is upstream of the filter, and all that metal garbage went through it and chewed it up. "Fixing up" the engine is spending money on an engine that will fail again very shortly, if it generates any oil pressure at all. Nothing less than complete teardown is necessary here. Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. I can only offer my own experience. My club had an Archer which showed metal in the oil filter. The engine had about 1300 SMOH, and this was the third run on the engine. We tried pulling cylinders and opening the oil pump trying to find the problem and ended up just throwing a lot of good money after bad. In the end, we racked up a lot of shop bills and still had to get a new engine. IHMO, the aviation gods have smiled upon you. They made the engine last long enough to get you safely on the ground so you could write that $21k check. The alternative could have been much worse. |
![]() IHMO, the aviation gods have smiled upon you. They made the engine last long enough to get you safely on the ground so you could write that $21k check. The alternative could have been much worse. I definitely agree. |
Ouch. I paid 20K and change for a Penn Yann O-540 rebuild to new limits
with everything new except the case and crank last summer. Yours is a 4 banger, right? I guess the turbo adds a bunch to it? "O. Sami Saydjari" wrote: Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
6 cylinders.
Ray Andraka wrote: Ouch. I paid 20K and change for a Penn Yann O-540 rebuild to new limits with everything new except the case and crank last summer. Yours is a 4 banger, right? I guess the turbo adds a bunch to it? "O. Sami Saydjari" wrote: Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
In Flight Failure | Charles Talleyrand | Military Aviation | 1 | August 4th 03 05:25 AM |
