On Sat, 24 Apr 2004 17:55:04 GMT, "John Kunkel"
wrote: "TTA Cherokee Driver" wrote in message ... Is there a fuel dip tube available for the Piper Warrior II (specifically, pa28-161)? Here's the data I used to make my dipstick (wood paint stirring stick) for 24 gallon tanks: 4= 0" 5= 1" 10= 2 1/4" 15= 4" 20= 5 3/4" 24= 7 1/4" I use a smooth wooden dowel abut 1/4" diameter and fitted a soft elastic tube over the the end to stop any chance of damaging the tank. The top has a small string loop to ensure it's not dropped into the tank (one of our group had the pleasure of removing and refitting a tank after dropping a calibrated tube inside!). Calibration is with a fine 'permanent' marker pen. Occasionally it needs re-marking but works well. Both tanks were calibrated by adding fuel, in increments, to our PA28-161, Warrior II. There was a slight discrepancy between tanks but not sufficient to cause any serious errors. It's nice to see some similarity with the poster above. I use the following which is from fuel added, measured then interpolated from calibration in litres. It is not on a linear scale. Dipped with stick approx. in middle of filler hole and on level ground: Inches USG ============ 8.0 24.7 7.0 23.5 6.0 21.8 5.0 19.4 TAB 17.5 4.0 16.6 3.0 13.3 2.0 9.3 1.0 6.3 0.0 4.3 David Piper Warrior G-BHJO Scotland, UK E-mail (Remove Space after pilot): pilot |
Any speculation on the corresponding data for Hershey-bar wing Cherokees?
We drive a 74 Archer. Same tank capacity as Warriors and 28-181 Archers, but the airfoil is presumably different, and therefore the tank sections are probably different. Anyone know if this is the case? Thanks. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney to love America wrote in message ... On Sat, 24 Apr 2004 17:55:04 GMT, "John Kunkel" wrote: "TTA Cherokee Driver" wrote in message ... Is there a fuel dip tube available for the Piper Warrior II (specifically, pa28-161)? Here's the data I used to make my dipstick (wood paint stirring stick) for 24 gallon tanks: 4= 0" 5= 1" 10= 2 1/4" 15= 4" 20= 5 3/4" 24= 7 1/4" I use a smooth wooden dowel abut 1/4" diameter and fitted a soft elastic tube over the the end to stop any chance of damaging the tank. The top has a small string loop to ensure it's not dropped into the tank (one of our group had the pleasure of removing and refitting a tank after dropping a calibrated tube inside!). Calibration is with a fine 'permanent' marker pen. Occasionally it needs re-marking but works well. Both tanks were calibrated by adding fuel, in increments, to our PA28-161, Warrior II. There was a slight discrepancy between tanks but not sufficient to cause any serious errors. It's nice to see some similarity with the poster above. I use the following which is from fuel added, measured then interpolated from calibration in litres. It is not on a linear scale. Dipped with stick approx. in middle of filler hole and on level ground: Inches USG ============ 8.0 24.7 7.0 23.5 6.0 21.8 5.0 19.4 TAB 17.5 4.0 16.6 3.0 13.3 2.0 9.3 1.0 6.3 0.0 4.3 David Piper Warrior G-BHJO Scotland, UK E-mail (Remove Space after pilot): pilot |
IIRC, the taper-wing Cherokees are only different outboard of the fuel tanks. The inboard chunk of the
wings have the same cross-section and thus the same fuel tank geometry. I'm not sure about the taperwing Arrows, since I think they're 36 gal each or something, rather than 25. I had the FBO fill up the tanks 5.0 gal at a time after I had to drain them for some reason. Dipped with a 1/2" wooden dowel and then scratched a line at each position. Very easy, and accurate to within \pm 1/s gallon. I'll contribute my measurements if interest merits. -Cory Bob Chilcoat wrote: : Any speculation on the corresponding data for Hershey-bar wing Cherokees? : We drive a 74 Archer. Same tank capacity as Warriors and 28-181 Archers, : but the airfoil is presumably different, and therefore the tank sections are : probably different. Anyone know if this is the case? Thanks. : -- : Bob (Chief Pilot, White Knuckle Airways) : I don't have to like Bush and Cheney to love America : wrote in message : ... : On Sat, 24 Apr 2004 17:55:04 GMT, "John Kunkel" : wrote: : : : "TTA Cherokee Driver" wrote in message : ... : Is there a fuel dip tube available for the Piper Warrior II : (specifically, pa28-161)? : : Here's the data I used to make my dipstick (wood paint stirring stick) : for : 24 gallon tanks: : : 4= 0" : 5= 1" : 10= 2 1/4" : 15= 4" : 20= 5 3/4" : 24= 7 1/4" : : : I use a smooth wooden dowel abut 1/4" diameter and fitted a soft : elastic tube over the the end to stop any chance of damaging the tank. : The top has a small string loop to ensure it's not dropped into the : tank (one of our group had the pleasure of removing and refitting a : tank after dropping a calibrated tube inside!). Calibration is with a : fine 'permanent' marker pen. Occasionally it needs re-marking but : works well. : : Both tanks were calibrated by adding fuel, in increments, to our : PA28-161, Warrior II. There was a slight discrepancy between tanks but : not sufficient to cause any serious errors. : : It's nice to see some similarity with the poster above. I use the : following which is from fuel added, measured then interpolated from : calibration in litres. It is not on a linear scale. Dipped with stick : approx. in middle of filler hole and on level ground: : : Inches USG : ============ : 8.0 24.7 : 7.0 23.5 : 6.0 21.8 : 5.0 19.4 : TAB 17.5 : 4.0 16.6 : 3.0 13.3 : 2.0 9.3 : 1.0 6.3 : 0.0 4.3 : : : David : : Piper Warrior G-BHJO : Scotland, UK : : E-mail (Remove Space after pilot): pilot -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Warrior Strobe Tube Replacement | Jerry Malin | Owning | 3 | September 29th 03 04:02 AM |
