A film of oil with some dirt attached is still transparent to the RF.
HOWEVER if you wipe the antenna that is attached to a thin skinned aircraft you will MOVE the antenna slightly. Maybe just enough to restore connection in the rusty connector joint or the broken solder joint. Wiping works just not for the reason stated. JF On Mon, 03 May 2004 17:49:46 -0600, mikem wrote: wrote: Clean oil is an insulator. An oil film with who knows what gunk in it is not such a good insulator. So, if you change the oil on your antenna regularly... Nevertheless, I stand by my statement. In order for dirty oil to effect the transmission, it would have to carbonize the oil into a conductive track shorting across the insulator at the base of the monopole. The peak power output from the transponder is about about 250W, which puts about SQR(250*50)=~110V across the antenna base. A little dirty oil will not arc over at 100V! MikeM |
mikem wrote:
wrote: Clean oil is an insulator. An oil film with who knows what gunk in it is not such a good insulator. So, if you change the oil on your antenna regularly... Nevertheless, I stand by my statement. In order for dirty oil to effect the transmission, it would have to carbonize the oil into a conductive track shorting across the insulator at the base of the monopole. The peak power output from the transponder is about about 250W, which puts about SQR(250*50)=~110V across the antenna base. A little dirty oil will not arc over at 100V! MikeM The oil doesn't have to carbonize, nor does it have to arc over to effect the antenna. The gunk caught in the oil only has to be lossy at 1 Ghz which most materials are. Old melmac dinnerware (the newer stuff seems to be better) would catch fire in a microwave on occasion because the stuff was so lossy at microwave frequencies. Melmac is a good insulator at DC. That would more likely show up as reduced range on the transponder unless the gunk was lossy enough to start carbonizing the oil, which I doubt would ever happen unless it got really thick (in which case you need to look at how you preflight). As someone else pointed out though, wiping the gunk off is a likely source of problems if you don't use a gentle touch on those little rod antennas. -- Jim Pennino Remove -spam-sux to reply. |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Spare Transponder Antenna? | Jim Weir | Home Built | 6 | May 25th 04 03:34 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
Transponder Antenna Question | Jay Honeck | Owning | 10 | December 29th 03 04:40 PM |
Wanted: Transponder antenna | Grandpa B. | Home Built | 22 | November 28th 03 08:03 AM |
