No I don't have a Carb Temp gauge..............from that comment I am
assuming you think that it would be a wise desision? On that note any recomendations as to what to get and how much to expect to pay? "Bill Hale" wrote in message om... ) wrote in message . com... I'll bet you are running unusually rich for whatever reason - even with carb heat off. To start off with though, the mixture distribution in carburated O-470s is poor. Whenever you pull carb heat on, the mixture gets really rich. You can get most of the power back by re-leaning. The distribution in O-470s can be fixed by running the carb heat such that the carb air temperature is 10C. They will smooth out and even lean of peak operations can be done. Courtesy of the excellent Advanced Pilot Seminar course. You DO have a carb temp gauge on this ice maker don't you? Bill Hale |
You can get an EI digital stand alone unit for a couple hundred. I have
mine as part of my engine analyzer. R.T. wrote: No I don't have a Carb Temp gauge..............from that comment I am assuming you think that it would be a wise desision? On that note any recomendations as to what to get and how much to expect to pay? "Bill Hale" wrote in message om... ) wrote in message e.com... I'll bet you are running unusually rich for whatever reason - even with carb heat off. To start off with though, the mixture distribution in carburated O-470s is poor. Whenever you pull carb heat on, the mixture gets really rich. You can get most of the power back by re-leaning. The distribution in O-470s can be fixed by running the carb heat such that the carb air temperature is 10C. They will smooth out and even lean of peak operations can be done. Courtesy of the excellent Advanced Pilot Seminar course. You DO have a carb temp gauge on this ice maker don't you? Bill Hale |
Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 01:48 AM |
rough running C-182 | R&A Kyle | Owning | 10 | November 16th 04 11:45 PM |
Carb heat specs? | Rich S. | Home Built | 2 | November 13th 04 04:39 PM |
alternate carb heat | Ray Toews | Home Built | 16 | October 29th 04 12:41 PM |
Help; Rough running Continental O-300D | JFLEISC | Owning | 11 | July 9th 04 01:31 AM |
