Michael,
The gauge is probably not read accurately. 60 AMPs is the max for the alternator for that airplane. The alternator output breaker should be 60 amp as well. if it was actually off the scale then the breaker should have popped. If it is truly going above 60 amp and not popping then the breaker needs to be replaced. Michelle Michael Bremer wrote: Well...I guess I should have given more info, sorry. It is a Piper Cherokee 180 (1968). We are talking about an alternator (pretty sure it is a Chrysler). The ammeter shows total load as opposed to charge/discharge. I also have a volt meter which shows steady at all RPM and loads. When I turn on the light the meter rises. It appears to be a stock meter that doesn't have a lot of numbers, basically "0" on the left, "30" in the center and "60" on the right. If I extrapolate/interpolate/guesstimate the readings, it is about 45-50 amps with everything turned on at idle RPM. At takeoff power, the needle swings as fat to the righ as it will travel. As the power is reduced, the needle settles back to the same 40-50 area. Thanks Mike "Michael Bremer" wrote in message link.net... Looking for some opinions and I know that there are no shortage of those here. I just returned from a little night ride to get my three landings and noticed what appears to be an abnormal reading from the ammeter. When on the ground, preparing for takeoff, I see a significant rise on the ammeter when I switch the landing light and fuel pump on. I know that this is normal, particularly with the landing light drawing a good bit of juice. The question is...When applying full engine power for takeoff, the ammeter rose off the scale. Not a sudden pop of the needle, but a pronounced rise as the RPM went up. When throttling back to cruise power, the meter drops to a more normal reading? Opinions??? Thanks Mike -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
AOPA credit card --- WARNING. | RS | Owning | 340 | December 9th 04 05:04 AM |
AutoGas question.. Jay Honeck, Jim Weir.. others.. | Dave S | Owning | 32 | November 11th 04 10:04 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
Good Electrical shop in NorCal | Robert M. Gary | Owning | 3 | May 6th 04 05:21 PM |
free credit report in seconds | Just Me | Aviation Marketplace | 2 | December 8th 03 12:47 AM |
