Michael Bremer wrote:
: When I turn on the light the meter rises. It appears to be a stock meter : that doesn't have a lot of numbers, basically "0" on the left, "30" in the : center and "60" on the right. If I extrapolate/interpolate/guesstimate the If indeed the meter reads these values, there is likely an AD against it. IIRC, the 0-60 Amp Loadmeters that were OK had a little white dot by the number "60". The ad is AD-86-17-01. I found that it had not been done on my airplane. The new loadmeter kit from Piper (PN 765-186) reads "0 35 70" although the alternator is still rated at 60A. I don't think that the AD is related to your problem, as it addresses the meter connections. The original meter is in series with the alternator output, which means that the 60A goes through the meter and a couple hefty bolts on the back of the instrument panel. The new meter is a shunt type, with about 6 feet of #2 wire for the shunt and 2 skinny wires (#20?) connecting to the meter itself. My old meter was sticking in cold weather. It would always indicate "0" no matter what when the temp was below freezing. I have heard of this happening in other Cherokees: the amp meter reads low in the winter. I don't think this is your problem either. I would guess that either the regulator is sticking or failed, or the starter is hanging up (as I said earlier). The starter is easy to check, to check the regulator measure the voltage somewhere convienient like the cig. lighter. If the voltage stays about the same with different engine speeds and loads, the regulator is probably OK. Please let us (me) know what you find out! -- Aaron Coolidge (N9367J) |
AOPA credit card --- WARNING. | RS | Owning | 340 | December 9th 04 05:04 AM |
AutoGas question.. Jay Honeck, Jim Weir.. others.. | Dave S | Owning | 32 | November 11th 04 10:04 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
Good Electrical shop in NorCal | Robert M. Gary | Owning | 3 | May 6th 04 05:21 PM |
free credit report in seconds | Just Me | Aviation Marketplace | 2 | December 8th 03 12:47 AM |
