The vertical fin on a C-150 is held on to the fuselage with a welded
steel bracket riveted into the aluminum structure. The welds are in the corners where the stress is highest. The steel undergoes galvanic corrosion when it is close to aluminum. These aircraft are being used well beyond their original intended lifetime and this steel fitting was cracked in the welds on the two 150s I'm familiar with. I thought it was a recent AD or at least a recent service letter. They were certainly not airworthy. This should be checked at annual on any 150 since it is an area of known service difficulty. The 172s don't have this problem with the bracket as it is an aluminum forging - not prone to corrosion. It would be one thing to lose a rudder, but losing both the rudder and vertical fin would be pretty exciting. It would be even worse if the rudder cables kept the separated surfaces attached to the rest of the airplane. |
Which is what would happen. Any control surface falling off is a
death sentence. Besides, the rudder is part of the vertical surface contributing to lateral stability. The airplane would be inclined to fly sideways without the rudder. Some aircraft, like my Jodel and many of the Zenair airplanes, have no fixed vertical surface and rely almost entirely on the rudder for stability. Dan |
Any control surface falling off is a death sentence.
I know a pilot who lost a control surface in a 150 Aerobat who will be very surprised to hear it. Rumors of his death are highly exaggerated. Michael |
![]() Any control surface falling off is a death sentence. Losing a rudder would be no big deal. Losing one aileron doesn't render the aircraft unflyable, lose both and you'd have to drive with the rudder. Losing one or both flaps isn't a big deal. |
the aircraft unflyable, lose both and you'd have to drive with the rudder. Losing one or both flaps isn't a big deal. BRBR I once watched a pipe line patrol hop in a 152, start it up and take off - missing an aileron. So much for a careful pre-flight. Came around the pattern, taxied back, shut her down and walked away. -- Dr. Nuketopia Sorry, no e-Mail. Spam forgeries have resulted in thousands of faked bounces to my address. |
Missing a control surface is different than losing one in flight.
Cables are pretty strong and might tend to hold on until something else breaks, and in the meantime there's a lot of unusual drag and flapping around going on. I sure wouldn't want to be aboard. A Cessna's aileron pushrod would probably bust right of and let the aileron go, but a rudder would be a different story. I'm an aircraft mechanic and a pilot. I hear stories that make me look at things closely. I have a mechanic friend who did some experimental reasearch on the cable breakage of Cessna 185 flap control system. They disconnected the LH flap and tried to see, in flight, what might happen if one was down and the other up. They were just able to keep it level with full aileron as the RH flap came all the way down. He said that if that cable broke suddenly at low level on approach there would be no way to control the airplane; it would roll over right away. Dan |
![]() wrote in message oups.com... Which is what would happen. Any control surface falling off is a death sentence. Not. Besides, the rudder is part of the vertical surface contributing to lateral stability. The airplane would be inclined to fly sideways without the rudder. Some aircraft, like my Jodel and many of the Zenair airplanes, have no fixed vertical surface and rely almost entirely on the rudder for stability. Dan |
Losing the rudder cleanly would probably be survivable as students have
been ignoring it for years. However, I contend that losing both the rudder and the vertical fin would almost certainly cause a crash. Any use of the ailerons in that circumstance would create a slight amount of adverse yaw moment that would have almost no reaction surface. The fuselage rear cone (especially on a later small tailcone diameter 150s) would not be very effective restoring moment just at the time when you would want to use a lot of the ailerons to get a semblance of steering. There is redundancy in the aileron system. There is no redundancy in the rudder/fin system. I do recall a picture in Aviation Week many years ago though that showed a B-52 with the whole vertical fin and rudder gone from a thunderstorm. Otherwise it would be the Sioux City DC-10 accident all over again but without the possibilities of differential engine thrust. No thanks. |
The Cessna's aileron control system uses bellcranks in
the wings, with pushrods from the bellcranks to the aileron, and cables from the bellcranks to the control wheels. A departed aileron would hopefully take the rod off and leave the airplane, and the bellcranks should continue to operate. If the rod didn't fail, or iff the bellcrank was damaged, the whole system would be fouled up. An airplane such as a Cub, or my Jodel, that has cables directly to the ailerons, would have no aileron control at all if one aileron failed. All the cable tensions are gone. You might have control in one direction, and not the other. Dan |
B2 Split Rudder | Emilio | Military Aviation | 8 | April 12th 04 10:43 AM |
P-51 Rudder Aerodynamics | Hawkeye Hughes | Home Built | 1 | March 15th 04 09:24 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
