Welcome to ownership. If my experience is any indication, after pouring
money into it for a few year to get it the way you want it, the money flow will lessen except for the inevitable periodic failures/replacements (e.g. exhaust system). re the pump; a wet pump without backup still puts you in a life threatening situation if it happens while in IMC. Assuming you maintain your partial panel skills, there is plenty of evidence that the failure to recognize the problem fast enough can be deadly. Clearly the wet pump reduces the chances but it does nothing to mitigate the risk if it does happen. The Precise Flight setup does give you that though it is not perfect. I would suggest that if you do decide to rely on one pump without backup, you should install a vacummn failure light (perhaps that is already a Cardinal feature?). That gives you what is arguably the most important component of the PF system, a warning of the failure. If you know it failed, you can immediately respond and perhaps avoid the main problem in such a failure, that is, detecting it quickly. Also, from a cost perspective, if you don't plan to fly in actual this year, then don't bother with the pump work. But it sounds like if you don't do the pump work, then you have the funds to get your IFR. Catch-22 wrote: Maule Driver wrote: It all sounds like good stuff but it's more of a set of small upgrades than an annual. MD, The most likely real annual job is the vaccum pump replacement. With the expected life of dry pump being 500hrs and the fact that they sometimes die without any advanced warning steered us toward the 2000hrs-life wet pump instead of getting a new dry pump + the Precise Flight backup system. You are right that these are more of a set of upgrades than what needed for an annual but an annual downtime is a good opportunity to 'upgrade' and fix little things which are not exactly airworthiness issue but can give us a peace of mind such as adding shoulder harnesses to the backseat, going with a more reliable pump etc.. When we first looking into buying a plane two years ago, we never thought of having to continue pumping greenbacks to it. It's almost like an addiction, you keep having the urge to feed the habit ;-) I had thought of delaying the paint job until next year so that we could spend on the IFR trips. Last weekend in seeing little flakes of paint came off while we were cleaning snow and ice of the poor Cardinal, I swore that I could hear our pet bird crying "I need a new plumage"! Hai Longworth |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
another year, another annual | Doug Vetter | Owning | 4 | November 22nd 03 11:40 AM |
'Good' Annual This Year | Ben Smith | Owning | 38 | July 26th 03 05:44 AM |
