On Tue, 18 Jan 2005 14:57:16 GMT, "Mike Rapoport"
wrote: No he isn't. Almost all the stuff listed is upgrades and is unrelated to the annual. Mike MU-2 Really? $2500 for a vacuum pump? $1K for glass? $1K for tips, $1K for nose paint? $500 to weigh the plane? Where do you shop? Or are you on the Boat & MB payment end? "Jon A." wrote in message .. . Find someone else to do your annuals. Make sure they don't have kids in college or boat or Mercedes Benz payments. Join the type club for your aircraft. You're simply paying too friggin' much! On 16 Jan 2005 19:12:31 -0800, " wrote: Our first annual last year increased our plane ownership cost by 50% (engine overhaul, prop governor overhaul + few other big ticket replacement parts + labor). When Rick and I tallied up all the things we want our AP to do this year, it looked like we have to reach deep into our pockets again. Here is the list 1. Replace the dry vacuum pump with an Airwolf wet pump + Air/oil separator(~$2500 not including labor - our AP estimated 1-2 days!). Our original plan was to get a new dry pump (the existing one has been spewing some carbon) + Precise Flight backup pump. Since we intend to get instrument rating and may attempt IFR traveling (probably mostly soft IFR), we think that the wet vacuum option would be a wiser choice and may even out the initial cost in the long run. 2. Replace all side windows and the back window. The windshield seems to be in good shape although our AP thinks that we will not like it as much once the other windows are replaced! Of course, we will also want to use the opportunity to add a photo window. This will most likely cost at least $1K not including labor (luckily our AP allows owner-assisted manual). 3. Replace the passenger seatbelt with shoulder harness/seatbelt. We replaced the pilot/copilot belts last year. The cost will be reasonable ($250 or something) but probably will take a bit of labor (will try to this ourselves again). 4. Install a cigarette lighter with multiple plugs. Probably will not cost much but this is something we must ask our AP to do. 5. Replace the two wingtips and one stabilator tip: ~ $1K in part. Not sure about labor. We can either do this now during the annual or let the paint shop do it. The same goes with the nose bowls. Our AP patched them up a bit last year but more extensive restoration will be required for the new paint job. One of the paint shops gave an estimate of $1K for the nose bowl job. 6. Miscellaneous stuffs: Attempt to reinstall the door bracket. Our AP tried it once but a previous repair attempt left some rivets in the wrong place so he had to pop the new bracket out. Pitot/Static/Transponder check: just hope that we don't have to replace anything else! Not sure of the cost. Last summer, Rick got the plane weighed (after we replaced some avionics and added thermal/sound insulation) and had the prop rebalanced. I was surprised to learn that it cost over $500 to weigh the plane but less than $200 for prop balancing. Replace the throttle control (again, just hope that it would be a minor job with minimum cost). Our annual is scheduled for Feb 15. I'm pretty sure we will think of few more items by then. The list above and the paint job (current estimates ranging from $10-$12K) will pretty much preclude us from taking any expensive vacations this year. There go most of our dive trips this year. Just hope that my 92 Honda Accord with over 230K miles will last few more years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Speaking of IFR training, I had thought of doing either a West Coast Adventures Trip with Field Morey or an East Coast IFR Trip with Dough Stewart. http://www.ifrwest.com/ http://www.dsflight.com/about.html No doubt that either one will be a tremendous learning experience and we will be much better pilots (and hopefully with instrument ratings) but those trips ain't cheap either. Maybe I should buy a lottery ticket ;-) Hai Longworth N30703 |
Jon,
We live in NY (just north of the city). Everything around here seems to be more expensive than in many other parts of the country. I do try to shop around online but some of the items are pretty much single-source such as the wet pump for Cardinal. Only Airwolf has it for close to $2K. The Air/Oil separator is $500. The photo window from LPAero plastics is $500/window. There are only two sources for fiberglass wingtips (Stene and Globe fiberglass) and none could be found for the nose bowl. If we have a more common plane such as C172, there would be more sources for parts but the Cardinal is our choice. All the paint shops within 200nm pretty much quote the same price range for painting. I may check out the Arkansas paint shop then weighing the pros and cons of saving some money vs. the logistic of getting the plane down there, back etc. esp if there are problems. Regarding annual cost, the AP rates around here are pretty much the same range ~ $70/hr. The current AP is one of the very few who would allow owner-assisted annual and his cost seems to be more reasonable. |
How many wet vacuume pumps have you had installed? The pump alone is $1850
with the separator listed at $495 at Aircraft Spruce. Add fittings and hoses to that.. He said that the tips and stab tip were $1000 for the parts. It is pretty clear that you have never had any of this stuff done. Mike MU-2 "Jon A." wrote in message ... On Tue, 18 Jan 2005 14:57:16 GMT, "Mike Rapoport" wrote: No he isn't. Almost all the stuff listed is upgrades and is unrelated to the annual. Mike MU-2 Really? $2500 for a vacuum pump? $1K for glass? $1K for tips, $1K for nose paint? $500 to weigh the plane? Where do you shop? Or are you on the Boat & MB payment end? "Jon A." wrote in message . .. Find someone else to do your annuals. Make sure they don't have kids in college or boat or Mercedes Benz payments. Join the type club for your aircraft. You're simply paying too friggin' much! On 16 Jan 2005 19:12:31 -0800, " wrote: Our first annual last year increased our plane ownership cost by 50% (engine overhaul, prop governor overhaul + few other big ticket replacement parts + labor). When Rick and I tallied up all the things we want our AP to do this year, it looked like we have to reach deep into our pockets again. Here is the list 1. Replace the dry vacuum pump with an Airwolf wet pump + Air/oil separator(~$2500 not including labor - our AP estimated 1-2 days!). Our original plan was to get a new dry pump (the existing one has been spewing some carbon) + Precise Flight backup pump. Since we intend to get instrument rating and may attempt IFR traveling (probably mostly soft IFR), we think that the wet vacuum option would be a wiser choice and may even out the initial cost in the long run. 2. Replace all side windows and the back window. The windshield seems to be in good shape although our AP thinks that we will not like it as much once the other windows are replaced! Of course, we will also want to use the opportunity to add a photo window. This will most likely cost at least $1K not including labor (luckily our AP allows owner-assisted manual). 3. Replace the passenger seatbelt with shoulder harness/seatbelt. We replaced the pilot/copilot belts last year. The cost will be reasonable ($250 or something) but probably will take a bit of labor (will try to this ourselves again). 4. Install a cigarette lighter with multiple plugs. Probably will not cost much but this is something we must ask our AP to do. 5. Replace the two wingtips and one stabilator tip: ~ $1K in part. Not sure about labor. We can either do this now during the annual or let the paint shop do it. The same goes with the nose bowls. Our AP patched them up a bit last year but more extensive restoration will be required for the new paint job. One of the paint shops gave an estimate of $1K for the nose bowl job. 6. Miscellaneous stuffs: Attempt to reinstall the door bracket. Our AP tried it once but a previous repair attempt left some rivets in the wrong place so he had to pop the new bracket out. Pitot/Static/Transponder check: just hope that we don't have to replace anything else! Not sure of the cost. Last summer, Rick got the plane weighed (after we replaced some avionics and added thermal/sound insulation) and had the prop rebalanced. I was surprised to learn that it cost over $500 to weigh the plane but less than $200 for prop balancing. Replace the throttle control (again, just hope that it would be a minor job with minimum cost). Our annual is scheduled for Feb 15. I'm pretty sure we will think of few more items by then. The list above and the paint job (current estimates ranging from $10-$12K) will pretty much preclude us from taking any expensive vacations this year. There go most of our dive trips this year. Just hope that my 92 Honda Accord with over 230K miles will last few more years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Speaking of IFR training, I had thought of doing either a West Coast Adventures Trip with Field Morey or an East Coast IFR Trip with Dough Stewart. http://www.ifrwest.com/ http://www.dsflight.com/about.html No doubt that either one will be a tremendous learning experience and we will be much better pilots (and hopefully with instrument ratings) but those trips ain't cheap either. Maybe I should buy a lottery ticket ;-) Hai Longworth N30703 |
Maybe you need to look a little closer at the options. Okay, I missed
the stab tips part, but if you can't get these for less than 1K, you're a sissy! On Wed, 19 Jan 2005 15:21:38 GMT, "Mike Rapoport" wrote: How many wet vacuume pumps have you had installed? The pump alone is $1850 with the separator listed at $495 at Aircraft Spruce. Add fittings and hoses to that.. He said that the tips and stab tip were $1000 for the parts. It is pretty clear that you have never had any of this stuff done. Mike MU-2 "Jon A." wrote in message .. . On Tue, 18 Jan 2005 14:57:16 GMT, "Mike Rapoport" wrote: No he isn't. Almost all the stuff listed is upgrades and is unrelated to the annual. Mike MU-2 Really? $2500 for a vacuum pump? $1K for glass? $1K for tips, $1K for nose paint? $500 to weigh the plane? Where do you shop? Or are you on the Boat & MB payment end? "Jon A." wrote in message ... Find someone else to do your annuals. Make sure they don't have kids in college or boat or Mercedes Benz payments. Join the type club for your aircraft. You're simply paying too friggin' much! On 16 Jan 2005 19:12:31 -0800, " wrote: Our first annual last year increased our plane ownership cost by 50% (engine overhaul, prop governor overhaul + few other big ticket replacement parts + labor). When Rick and I tallied up all the things we want our AP to do this year, it looked like we have to reach deep into our pockets again. Here is the list 1. Replace the dry vacuum pump with an Airwolf wet pump + Air/oil separator(~$2500 not including labor - our AP estimated 1-2 days!). Our original plan was to get a new dry pump (the existing one has been spewing some carbon) + Precise Flight backup pump. Since we intend to get instrument rating and may attempt IFR traveling (probably mostly soft IFR), we think that the wet vacuum option would be a wiser choice and may even out the initial cost in the long run. 2. Replace all side windows and the back window. The windshield seems to be in good shape although our AP thinks that we will not like it as much once the other windows are replaced! Of course, we will also want to use the opportunity to add a photo window. This will most likely cost at least $1K not including labor (luckily our AP allows owner-assisted manual). 3. Replace the passenger seatbelt with shoulder harness/seatbelt. We replaced the pilot/copilot belts last year. The cost will be reasonable ($250 or something) but probably will take a bit of labor (will try to this ourselves again). 4. Install a cigarette lighter with multiple plugs. Probably will not cost much but this is something we must ask our AP to do. 5. Replace the two wingtips and one stabilator tip: ~ $1K in part. Not sure about labor. We can either do this now during the annual or let the paint shop do it. The same goes with the nose bowls. Our AP patched them up a bit last year but more extensive restoration will be required for the new paint job. One of the paint shops gave an estimate of $1K for the nose bowl job. 6. Miscellaneous stuffs: Attempt to reinstall the door bracket. Our AP tried it once but a previous repair attempt left some rivets in the wrong place so he had to pop the new bracket out. Pitot/Static/Transponder check: just hope that we don't have to replace anything else! Not sure of the cost. Last summer, Rick got the plane weighed (after we replaced some avionics and added thermal/sound insulation) and had the prop rebalanced. I was surprised to learn that it cost over $500 to weigh the plane but less than $200 for prop balancing. Replace the throttle control (again, just hope that it would be a minor job with minimum cost). Our annual is scheduled for Feb 15. I'm pretty sure we will think of few more items by then. The list above and the paint job (current estimates ranging from $10-$12K) will pretty much preclude us from taking any expensive vacations this year. There go most of our dive trips this year. Just hope that my 92 Honda Accord with over 230K miles will last few more years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Speaking of IFR training, I had thought of doing either a West Coast Adventures Trip with Field Morey or an East Coast IFR Trip with Dough Stewart. http://www.ifrwest.com/ http://www.dsflight.com/about.html No doubt that either one will be a tremendous learning experience and we will be much better pilots (and hopefully with instrument ratings) but those trips ain't cheap either. Maybe I should buy a lottery ticket ;-) Hai Longworth N30703 |
![]() Jon A. wrote: Maybe you need to look a little closer at the options. Okay, I missed the stab tips part, but if you can't get these for less than 1K, you're a sissy! Jon, Do you know of any other sources for fiberglass tips? Stene Aviation has the C177B wingtips at $350 a piece and the stab tips at $150 a piece ($350 + $150 then x2 = $1K). Globe has the wintips a bit cheaper at $300 a piece but the stab tip pair is $400 so this comes out to be just under $1K. Have not been able to locate any other sources. Last I checked, the websites of those places did not have a gender-specific price list ;-) Hai |
Mike Rapoport wrote:
How many wet vacuume pumps have you had installed? The pump alone is $1850 with the separator listed at $495 at Aircraft Spruce. Add fittings and hoses to that.. He said that the tips and stab tip were $1000 for the parts. It is pretty clear that you have never had any of this stuff done. No, what's clear is that you have no real idea of how maintenance works in the real world of light piston airplanes. Who in the world would buy a new wet pump and separator from Aircraft Spruce? Certainly nobody I know. Those things last essentially forever, there were tons of them manufactured decades ago, and they're everywhere. You can have one overhauled for much less than the cost of a new dry pump, and you get old ones from any salvage yard. Any mechanic worth his salt knows how to do this. The mechanic who just orders new from Aircraft Spruce is going to cost you a lot of money. Michael |
![]() Michael wrote: You can have one overhauled for much less than the cost of a new dry pump, and you get old ones from any salvage yard. And you get the STC to install it on a Cessna 177 where? George Patterson The desire for safety stands against every great and noble enterprise. |
![]() G.R. Patterson III wrote: Michael wrote: You can have one overhauled for much less than the cost of a new dry pump, and you get old ones from any salvage yard. And you get the STC to install it on a Cessna 177 where? George, As far as I know, only Airwolf wetpump has STC to install it on C177 (and only recently - a fellow Cardinal owner ordered the wetpump late last year and had to wait few months for the official paperwork). We contacted M20 about their wetpump but it has not been approved for C177 yet and they can not tell us how long it will take or how much it will cost. I honestly don't believe that a new wetpump could cost significantly more than a rebuilt pump and most likely very little if any modifications are required for the pump to be used in similar aircraft type. The first company who has the wetpump STC for certain aircraft pretty much a monopoly until there are more competitors. We were also checking into replacing the cowling fasteners to 1/4-turn type (we change oil every 25hrs and fly at least 150hrs/yr), and were appalled to learn that the STC'ed Skybolt SS conversion kit cost over $500 for C177!! Thanks. -------------------------------------------- To all who had kindly replied/participated in this thread: We are new to plane ownership (a bit less than 2 years) and have a lot to learn. I posted our upgrade plan for this annual to get feedbacks not only on the soundness of the plan but also for information for better suppliers/prices. Thank you for your advices, symphaties and information. Hai Longworth |
![]() " wrote: As far as I know, only Airwolf wetpump has STC to install it on C177 I thought that might be the case. George Patterson The desire for safety stands against every great and noble enterprise. |
The what? The where?
Oh, that was on there when I bought the airplane ten years ago... Jim "G.R. Patterson III" wrote in message ... Michael wrote: You can have one overhauled for much less than the cost of a new dry pump, and you get old ones from any salvage yard. And you get the STC to install it on a Cessna 177 where? George Patterson The desire for safety stands against every great and noble enterprise. |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
another year, another annual | Doug Vetter | Owning | 4 | November 22nd 03 11:40 AM |
'Good' Annual This Year | Ben Smith | Owning | 38 | July 26th 03 05:44 AM |
